ISR 4331 + SM-X-ES3-16-P - Exit?
GTC Hubgrade
i've a ISR 4331 with a SM-X-ES3-16-P module, when i'm accessing trough console to the ISR then i access to the module, i don't find a way to exit the module and return to the router console, i've tried ctrl+shift+6+^x plus disconnect, ctrl+^c, commands exit, end but the connection remains, i only return to the console router session when i reload the physical equipment, anyone knows a way to exit the module?
Michael Deku
A post in this discussion has been removed due to possible misconduct. Please refer to the CSC terms of use for more details.
dscrimpsher
When you open a session with the SM-X-ES3-16-P module you should have seen the notice (below) about how to exit the session. You need to enter CTRL+a CTRL+q to exit the session.
Establishing session connect to subslot 1/0
To exit, type ^a^q
picocom v1.4
port is        : /dev/ttyDASH0
flowcontrol    : none
baudrate is    : 9600
parity is      : none
databits are   : 8
escape is      : C-a
noinit is      : no
noreset is     : no
nolock is      : yes
send_cmd is    : ascii_xfr -s -v -l10
receive_cmd is : rz -vv
Terminal ready
SM-X-ES3-16-P
Thanks for the tip. I was trying to type ^a^q instead of using the Ctrl keys.
