02-12-2024 09:14 AM
This should be an easy question. We have a customer who has couple of ISR4321 routers and would like to know if they have the Performance Boost License is installed or not. We don't have remote access to routers and I wanted to find out which commands can be executed to produce that information? Is it "show license" or "show license all" or there are commands that could be used?
Thanks in advance.
Thank you, ~zK
02-12-2024 09:21 AM
yes that should give information - check below guide also help you :
02-12-2024 09:23 AM
02-12-2024 09:49 AM
BTW, keep in mind, boost level performance is very, very dependent on router configuration and traffic mix. I.e. worst case, throughput at about performance level, best (ideal) case, throughput as noted in the image @Georg Pauwen provided.
If you need to know expected actual throughput, you might want to review this Miercom Performance Analysis Report :
02-12-2024 11:14 AM
This is the output as a result of issuing this command "show license all"
License Usage ============= booster_performance (ISR_4321_BOOST): Description: booster_performance Count: 1 Version: 1.0 Status: IN USE Export status: NOT RESTRICTED Feature Name: booster_performance Feature Description: booster_performance Enforcement type: NOT ENFORCED License type: Perpetual
Just to confirm, this means that the boos license is installed and active, correct?
Thank you, all!
~zK
02-12-2024 02:02 PM
@ZK916 wrote:
Status: IN USE
Boot License is in active.
What firmware is the router on, is it 16.9.X and earlier?
02-12-2024 05:24 PM
I am not sure. I didn't ask for the "sh ver".
Just curious, would the firmware version have an impact on the licensing type?
02-12-2024 05:56 PM
IOS xe version before 16.9.X was standard pak license, later IOS XE code required smart license.
02-12-2024 07:30 PM
If I am right, the router is NOT on Smart License.
The license is different when the router is on a firmware when Smart License is enabled.
