Static Routing Won't Save and Destination Host Unreachable
airlux dsaasd
I use static routes. but when I add ip route on the router it is not saved. when I do
 "ip show route"
it doesn't show the IP route that I gave before. but in the config routing interface, there is the ip route that I added earlier
Please help me. Am I wrong in doing the ip calculation on the ip route that I wrote?
VLSM Table
IP Configuration
@airlux dsaasd hi, issue is your next hop is not reachable. (10.44.8.121). correct gateway need to be 10.44.8.113. and according to the topology details, you entered wrong IPs to wrong interfaces in Router0.
Fa6/0 should be 10.44.8.113
fa1/0  should be 10.44.8.121
fa 0/0 need to be 10.44.8.117
Good luck
KB
Good luck
KB
I have changed the ip on router 0. but the result is still the same when I have added the ip route it has no effect at all. is there an error in the destination/next hop I have?
Sorry, I forgot to change the gateway/next hop on the static route. after I changed it normally runs now. Thank you very much for your help Kasun Bandara.
