L2VPN Over GRE
jm-barreto
I'm trying to extended a L2 segment using MPLS L2vpn over GRE. I am able to establish the tunnel and get ospf and mpls adjacency also the xconnect between the peer is up but my 2 test pc cant reach each other.
This is my PE3 config.
interface GigabitEthernet0/0/0/0
mtu 1560
interface GigabitEthernet0/0/0/0.101 l2transport
encapsulation untagged
interface tunnel-ip10
ipv4 address 10.2.3.2 255.255.255.252
tunnel source GigabitEthernet0/0/0/1
tunnel destination 172.16.50.2
router static
address-family ipv4 unicast
172.16.50.0/30 GigabitEthernet0/0/0/1 172.16.51.1
router ospf 1
nsr
router-id 3.3.3.3
mpls ldp auto-config
nsf cisco
area 1
network point-to-point
mpls traffic-eng
interface Loopback0
mpls traffic-eng router-id Loopback0
mpls traffic-eng
mpls ldp
log
hello-adjacency
neighbor
nsr
graceful-restart
discovery
hello holdtime 5
hello interval 1
router-id 3.3.3.3
mpls oam
l2vpn
router-id 3.3.3.3
xconnect group test
p2p test
neighbor ipv4 1.1.1.1 pw-id 55555
RP/0/RP0/CPU0:PE3#sh cef tunnel-ip10
Mon Apr 15 17:21:14.820 UTC
Prefix Next Hop Interface
1.1.1.1/32 10.2.3.1/32 tunnel-ip10
2.2.2.2/32 10.2.3.1/32 tunnel-ip10
10.1.2.0/30 10.2.3.1/32 tunnel-ip10
10.2.3.0/30 attached tunnel-ip10
10.2.3.0/32 broadcast tunnel-ip10
10.2.3.2/32 receive tunnel-ip10
10.2.3.3/32 broadcast tunnel-ip10
RP/0/RP0/CPU0:PE3#sh ospf neighbor
Mon Apr 15 17:21:42.745 UTC
* Indicates MADJ interface
# Indicates Neighbor awaiting BFD session up
Neighbors for OSPF 1
Neighbor ID Pri State Dead Time Address Interface
2.2.2.2 1 FULL/ - 00:00:39 10.2.3.1 tunnel-ip10
Neighbor is up for 00:07:56
Total neighbor count: 1
RP/0/RP0/CPU0:PE3#sh mpls ldp neighbor
Mon Apr 15 17:21:50.007 UTC
Peer LDP Identifier: 1.1.1.1:0
TCP connection: 1.1.1.1:646 - 3.3.3.3:21530
Graceful Restart: No
Session Holdtime: 180 sec
State: Oper; Msgs sent/rcvd: 26/19; Downstream-Unsolicited
Up time: 00:07:55
LDP Discovery Sources:
IPv4: (1)
Targeted Hello (3.3.3.3 -> 1.1.1.1, active)
IPv6: (0)
Addresses bound to this peer:
IPv4: (2)
1.1.1.1 10.1.2.1
IPv6: (0)
Peer LDP Identifier: 2.2.2.2:0
TCP connection: 2.2.2.2:646 - 3.3.3.3:23252
State: Oper; Msgs sent/rcvd: 12/11; Downstream-Unsolicited
Up time: 00:01:59
IPv4: (1)
tunnel-ip10
IPv6: (0)
IPv4: (4)
2.2.2.2 10.1.2.2 10.2.3.1 172.16.50.2
IPv6: (0)
RP/0/RP0/CPU0:PE3#sh ip route
Mon Apr 15 17:21:55.506 UTC
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
U - per-user static route, o - ODR, L - local, G - DAGR, l - LISP
A - access/subscriber, a - Application route
M - mobile route, r - RPL, t - Traffic Engineering, (!) - FRR Backup path
Gateway of last resort is not set
O 1.1.1.1/32 [110/1002] via 10.2.3.1, 00:08:09, tunnel-ip10
O 2.2.2.2/32 [110/1001] via 10.2.3.1, 00:08:09, tunnel-ip10
L 3.3.3.3/32 is directly connected, 02:11:35, Loopback0
O 10.1.2.0/30 [110/1001] via 10.2.3.1, 00:08:09, tunnel-ip10
C 10.2.3.0/30 is directly connected, 01:52:52, tunnel-ip10
L 10.2.3.2/32 is directly connected, 01:52:52, tunnel-ip10
L 127.0.0.0/8 [0/0] via 0.0.0.0, 02:11:38
S 172.16.50.0/30 [1/0] via 172.16.51.1, 02:11:35, GigabitEthernet0/0/0/1
C 172.16.51.0/30 is directly connected, 02:11:35, GigabitEthernet0/0/0/1
L 172.16.51.2/32 is directly connected, 02:11:35, GigabitEthernet0/0/0/1
RP/0/RP0/CPU0:PE3#sh l2vpn xc
Mon Apr 15 17:22:15.036 UTC
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
SB = Standby, SR = Standby Ready, (PP) = Partially Programmed,
LU = Local Up, RU = Remote Up, CO = Connected, (SI) = Seamless Inactive
XConnect Segment 1 Segment 2
Group Name ST Description ST Description ST
test test UP Gi0/0/0/0.101 UP 1.1.1.1 55555 UP
23 Replies 23
can you post the full running configs of the other PEs as well ?
Will do in a moment.
The config is confuse me
You use mpls te, So please confirm that mpls te not use for l2vpn over gre.
Second
You need to use mpls ip in tunnel you use between two peer.
And config static route for IP of peer reach via tunnel.
And config mpls router ID loop back
Hope this solve your issue
MHM
Hi @MHM Cisco World No, im not using TE. It is there but it not use. MPLS is configure and with router id.
mpls ldp
log
hello-adjacency
neighbor
nsr
graceful-restart
discovery
hello holdtime 5
hello interval 1
router-id 3.3.3.3
The interface is enable fo MPLS
router ospf 1
nsr
router-id 3.3.3.3
And i got static route
router static
The mpls is up even the l2vpn xconnect is up
Up time: 00:07:55
IPv4: (1)
IPv6: (0)
IPv4: (2)
1.1.1.1 10.1.2.1
IPv6: (0)
Up time: 00:01:59
IPv4: (1)
tunnel-ip10
IPv6: (0)
IPv4: (4)
IPv6: (0)
Everything seems to be up (OSPF,MPLS,L2VPN) but my test pc cant reach.
If i use a direct connection it work but no via the GRE tunnel
The mpls exchange label via tunnel, you don't config mpls under tunnel?
Do show mpls forwarding label
Check if the label is assign to VC 55555
Yes it is enable
RP/0/RP0/CPU0:PE3#sh mpls forwarding
Mon Apr 15 19:09:30.554 UTC
Local Outgoing Prefix Outgoing Next Hop Bytes
Label Label or ID Interface Switched
24000 Unlabelled 172.16.50.0/30 Gi0/0/0/1 172.16.51.1 1965134
24001 24001 1.1.1.1/32 ti10 10.2.3.1 576
24002 Pop 2.2.2.2/32 ti10 10.2.3.1 142
24003 Pop 10.1.2.0/30 ti10 10.2.3.1 0
24004 Pop PW(1.1.1.1:55555) Gi0/0/0/0.101 point2point 0
the command mpls auto-config in router ospf, enable mpls ip in all the interface that is under ospf
jm-barreto
@Georg Pauwen @MHM Cisco World
Here the full configuration
Thanks in advance
Did you force mpls to use loopback ad router ID as I mention before ?
Yes. I use the Loopback interface as router-id for mpls and is explicit configured under the mpls section.
Ej:
mpls ldp
log
hello-adjacency
neighbor
nsr
graceful-restart
discovery
hello holdtime 5
hello interval 1
router-id 3.3.3.3
mpls oam
Harold Ritter
Hi @jm-barreto ,
At first sight, I would say your configurations look good. Can you provide the "show l2vpn xconnect detail" from both PE1 and PE3.
PE1
PE3
Hi @jm-barreto ,
The output provided shows that the PW is down.
Can you provide the following:
from PE1:
show cef 3.3.3.3/32 det
ping mpls ipv4 3.3.3.3/32 source 1.1.1.1
from PE3:
show cef 1.1.1.1/32 det
ping mpls ipv4 1.1.1.1/32 source 3.3.3.3
Hi @Harold Ritter here the requested output
