LAN not communicating with WAN
andylee1892
Hi all,
Writing my first router config from scratch for an 1801.  I have wireless devices able to connect & authenticate with WPA.  Wired devices can talk with wireless devices & on both interfaces devices obtain a DHCP lease.  I can ping web based resources from the FA0 interface; the problem is, LAN devices can't ping has FA0.  I'm pretty sure (well a hunch) that this is going to be down to NAT
Have I gone completely wrong with this?
Thanks for any help
version 12.4
service password-encryption
hostname Router0
boot-start-marker
boot-end-marker
enable secret xxxxxxxxx
no aaa new-model
dot11 syslog
dot11 ssid TEST_NETWORK
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii xxxxxxxxx
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.126 192.168.1.254
ip dhcp pool Client-Pool
   import all
   network 192.168.1.0 255.255.255.0
   domain-name domain.com
   dns-server 192.168.1.1 8.8.8.8
   default-router 192.168.1.1
ip domain name domain.com
ip name-server 192.168.1.1
ip name-server 8.8.8.8
ip name-server 4.2.2.2
ip name-server 208.67.220.220
ip name-server 208.67.222.222
username xxxxxxxxx privilege 15 password xxxxxxxxx
archive
log config
  hidekeys
bridge irb
interface FastEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
description test
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid TEST_NETWORK
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
ssid TEST_NETWORK
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
no ip address
ip nat inside
bridge-group 1
interface BVI1
description $ES_LAN$
ip forward-protocol nd
ip http server
ip http port 2002
no ip http secure-server
ip nat pool NAT_POOL 192.168.1.0 192.168.2.0 netmask 0.0.0.255
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
2 Accepted Solutions
yes indeed if it is cable modem then no need for DSL module
Alain
int vlan 1
no ip nat inside
int bvi1
ip nat inside
Alain
10 Replies 10
Pawan Sharma
I think command 'IP ROUTING' should solve the purpose.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
Thanks Pawan
I issued this command at global config mode however it hasn't made a difference
andylee1892
OK, I have previously been going through the config guide here
When issuing the command "vpdn enable" I am not put into the mode Hostname(config-vpdn)# as the instructions state I should be; "vpdn enable" has no visible effect and leaves me at the global configuration mode.  I therefore can't follow the rest of the commands and can't set up the virtual dialup private network.  With a bit of experimentation, I can enter the following:
I enter::            Hostname(config)#vpdn-group 1
Guide says::     Hostname(config-vpdn)# vpdn group 1
I enter::            Hostname(config-vpdn)#request-dialin
Guide Says::    Hostname(config-vpdn-grp)# request-dialin
These are the only commands I can enter that bear any resemblance to the guide; however the commands differ slightly and are at different modes.  The guide also has Hostname(config-vpdn-grp)# initiate to 192.168.1.1 which I simply can't enter.
Does anyone know the correct syntax, whether or not I actually need to configure this to achieve my aim & also why the guide for the 1800 series router contains commands I can't enter at the CLI ???
Scratch the above... the first line of this section in the guide reads "The Cisco 1811 and Cisco 1812 integrated services  fixed-configuration routers support Point-to-Point Protocol over  Ethernet (PPPoE) clients and network address translation (NAT). "
As I have an 1801 these commands obviously won't work!! Now i'm really stumped - the guide for the 1801 shows WAN configuration using the ATM interface & DSL
You'll need this: http://www.cisco.com/en/US/prod/collateral/routers/ps221/product_data_sheet0900aecd8028aa5a_ps5853_Products_Data_Sheet.html
Alain
Thanks cadet alain, but I don't have a DSL, I am connecting to a cable modem via the FA0 port on my 1801!
As per the OP, I can ping www.google.com from the router - so my cable modem is assigning an IP address and I have connectivity at the WAN.  LAN devices talk to each other (wired & wireless) the problem is with the LAN talking to the WAN.  I just don't know how to get traffic from the LAN to the WAN and back again   I may be wrong, but I don't this an ADSL module would rectify this
Alain
OK, cheers CA.  Any ideas where I'm going wrong with the config
int vlan 1
no ip nat inside
int bvi1
ip nat inside
Alain
Sorry it has taken so long to get back, I have been away.
Cadet Alain, your answer worked a treat, thanks very much
