Large Backups across MPLS WAN
mdargin
We are opening up a second data center at my organization. The location is about 60 miles from our primary data center.
At our primary data center we use an MPLS network for our WAN. We have ll remote locations on our WAN and we have a DS-3 that connects to our primary data center.
At our new second data center we will connect it to the MPLS network.
Do you think we should run our backups between the 2 data centers across the MPLS or do you think we should order a seperate private line or ethernet type service between the 2 data centers? All back ups from our primary data center will continually move across the network to our new secondary data center.
Do you think MPLS is a good technology to run large back ups across? Is it reliable enough
paolo bevilacqua
Yes considering you will keep the circuit busy all time it is a good idea to run it on a dedicated facility.
The deciding factor are not he technology used, all are reliable, but the bandwidth you get for the money you pay.
Jon Marshall
Mark
It's not really a question of reliable enough more a question of how much data you need to backup, when it needs backing up and how important this data is.
If the combined backup data and normal business traffic is more than your links bandwidth at the primary data center then something has to give. If you prioritise business traffic then there is the possibility your backups might not complete in time. If you prioritise backup data there is the possibility of impacting on business traffic.
Also it depends on how you intend to use the backup data ie. how quickly do you need the backup data to be written to the secondary data center. Do you intend to fail over automatically if the primary data center fails.
Personally in the Enterprises i have worked there were standard approaches
1) If an overnight backup is good enough then use the production links as long as the backup window does not overlap with production hours
2) If backups are needed throughout the day but are in a drip feed form where there is still available bandwidth and there is no need for a guaranteed write time then you can use production links but you need to closely monitor the backup traffic.
3) If a guarantee is needed for write time eg database traffic use dedicated link or use QOS to priortise the traffic but it is unlikely the business will want it's core hours traffic disrupted.
4) If backups must run during the day but the backup + business traffic exceed the bandwidth available then either -
i) if backup traffic does not require quarantees you could look to use QOS to ensure the backup traffic does not impact business traffic
ii) if guarantees are required then dedicated link.
Jon
