License Install command Not available in my CSR1000v (16.10)
danntel01
Hi Community,
Having issues installing a demo license for my CSR100v. I have already copied the license file to the VM, but can't install it, the command:
cme-01#license ?
smart Smart licensing
cme-01#license
I only have the option to do license smart....and that's not what i want since i created my .lic file and downloaded to my PC and then via copy TFTP i uploaded to the router vm. I'm a bit lost here.
I followed this guide:
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1000v_Configuration_Guide/b_CSR1000v_Configuration_Guide_chapter_01000.html
Refer to Step 4 (license install stored-location-url)
Here's my version:
cme-01#show version
Cisco IOS XE Software, Version 16.10.01a
Cisco IOS Software [Gibraltar], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.10.1a, RELEASE
14 Replies 14
smart licensing disables software licensing. Disable smart licensing:
CSR1000v#conf t
CSR1000v(config)#no license smart enable
Unfortunately, that doesn't seem to work:
cme-01#configure t
Enter configuration commands, one per line. End with CNTL/Z.
cme-01(config)#no license smart enable
% Invalid input detected at '^' marker.
cme-01(config)#no license smart ?
custom_id Set a customer defined id
privacy privacy related commands
reservation Enable or disable the license reservation feature
transport Select the type of message transport for Smart Agent
url Set the Smart Transport Primary and the Utility URL
utility Enable or disable usage reporting on the device
try 'no service call-home' in global config mode first...
Looks like same thing, no way to run "license install" command
cme-01#configure terminal
cme-01(config)#no service call-home
cme-01(config)#no license smart ? custom_id Set a customer defined id privacy privacy related commands reservation Enable or disable the license reservation feature transport Select the type of message transport for Smart Agent url Set the Smart Transport Primary and the Utility URL utility Enable or disable usage reporting on the device
cme-01#license ?
what is the output of 'show license detail' ? Have you actually booted to any of the licenses availabe ?
1.enable
2.configure terminal
3.license boot level {standard | advanced | premium}
Accept the EULA.
4.end
5.write memory
6.reload
7.show license detail
cme-01(config)#license boot level ?
  appx      Enable appx license
  ax        Enable ax(ipb+sec+appx) license
  ipbase    Enable ipbase license
  security  Enable security license
cme-01(config)#license boot level ax
% use 'write' command to make license boot config take effect on next boot
cme-01(config)#do wr
Building configuration...
[OK]
reload
cme-01#show license ?
  all          Show license all information
  reservation  Show license reservation information
  status       Show license status information
  summary      Show license summary
  tech         show license tech support information
  udi          Show license udi information
  usage        Show license usage information
cme-01#show license
cme-01#license ?
cme-01#show license status
Smart Licensing is ENABLED
Utility:
  Status: DISABLED
Data Privacy:
  Sending Hostname: yes
    Callhome hostname privacy: DISABLED
    Smart Licensing hostname privacy: DISABLED
  Version privacy: DISABLED
Transport:
  Type: Callhome
Registration:
  Status: UNREGISTERED
  Export-Controlled Functionality: NOT ALLOWED
License Authorization:
  Status: EVAL MODE
  Evaluation Period Remaining: 88 days, 6 hours, 10 minutes, 12 seconds
Export Authorization Key:
  Features Authorized:
Any ideas please?
what happpens when you type 'license smart enable', reload the device, and then type 'no license smart enable' ?
There's no such command "license smart enable"
what happens if you configure 'no license smart reservation' ?
I just checked the release notes for Gibraltar 16.10. Only Smart Licensing is supported:
Release Gibraltar 16.10.1b supports Smart License as the only Licensing mode Refer Smart Licensing Guide for Access and Edge Routers for more details. A Smart Account is mandatory Use Device Led Conversion (DLC) to convert traditional licenses to Smart (DLC for CSR1000v will come in 17.1.1)
Hi Georg,
           Version 17.1.1 is tied to smart ONLY, although gives you a chance to convert traditional to smart, if you DON'T want to have the smart license feature and want traditional then you will need to downgrade to 16.10.1a or earlier
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/smart-licensing/qsg/b_Smart_Licensing_QuickStart/b_Smart_Licensing_QuickStart_chapter_011.html
Kind Regards Jon
I had a similar issue and I had to downgrade from isr4300-universalk9.17.03.05.SPA.bin to an older version and it worked.
BrianSekleckiGE
So if one wants to evaluate APPX_5G or AX_5G on CSR1000V using the latest IOS-XE, we do what? Request/Ask Cisco reseller to issue an evaluation license to our SmartNet account?
