Load Sharing between two MPLS ISP in Cisco 892 Router
asifmohamamed
I am having Cisco 892 router which has two ISP(MPLS), and i configured auto failover between two ISP.
Also configured a Load sharing between two ISP.
Configuration attached for reference
Auto fail over is working fine but In load sharing Intranet site is working and Internet is not working
could you please check configuration and recommend the necessary changes.
Hi Asif,
How are you monitoring that load sharing is not working while internet traffic?
I see according to your config you have setup policy base routing so according to policy base routing internet traffic will use only Aircel Link.
Spooster IT Services Team
Deepak Kumar
You have configured PBR for forwarding Internet traffic (Except your branches) to Aircel ISP.
Please check your below configuration which is forwarding all traffic to Aircel ISP:
ACL 101, Route-map "PBR" Sequence 30.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
