Mikrotik to Cisco Configuration Convert
Sellamuthu Ravi
Hello Everyone,
 I am new to Mikrotik ROuter Configuration ,
i Will Share the Mikrotik Commands to be convert Cisco Commands
Can we please anyone help to me
1 .
/ip firewall mangle add action=mark-routing chain=prerouting comment=infyn in-interface=WAN_IFACE new-routing-
mark=infyn passthrough=yes protocol=tcp src-port=80 disabled=yes
2.
/ip firewall mangle add action=mark-routing chain=prerouting comment=infyn dst-port=80 in-interface=LAN_IFACE
new-routing-mark=infyn passthrough=yes protocol=tcp src-address=!CACHE_SERVER_ADDRESS disabled=yes
3. /ip firewall nat add action=dst-nat chain=hotspot dst-port=53 protocol=udp src-address=!CACHE_SERVER_ADDRESS to-
addresses=CACHE_SERVER_ADDRESS \
to-ports=53 disabled=yes
4.
/ip firewall nat add action=dst-nat chain=dst-nat dst-port=53 protocol=udp src-address=LAN_NET_IP_POOL to-
addresses=CACHE_SERVER_ADDRESS to-ports=53 disabled=yes
5. ip firewall mangle action=mark-routing chain=prerouting comment=infyn dst-port=53 add in-interface=LAN_IFACE
new-routing-mark=infyn passthrough=yes protocol=udp src-address=!CACHE_SERVER_ADDRESS disabled=yes
6.
/ip firewall mangle add action=mark-routing chain=prerouting comment=infyn in-interface=WAN_IFACE \
new-routing-mark=infyn passthrough=yes protocol=udp src-port=53 disabled=yes
7.
/ip route add comment=infyn distance=1 dst-address=10.254.200.0/24 gateway=CACHE_SERVER_ADDRESS scope=30 target-
scope=10 routing-mark=infyn disabled=yes
Thank You
YOUR FRIEND.
Line 1 an 7 are similiar to a PBR with extended ACL in Cisco.
Line 1 is marking any TCP traffic with source port 80 ingress from WAN Interface. In MikroTik you can put a name to an Interface so WAN_IFACE could be a G0/0 in Cisco.
Line 7 is defining in the route table that trafic that match the Line1 parameters goes to the gateway CACHE_SERVER_ADDRESS, this gateway is just an IP that is replaced with a name. In the example that I giving to you is 10.50.0.1. Just replace.
ACL
#ip access-list extended infyn
#permit tcp any eq www 10.254.200.0 0.0.0.255
PBR
#route-map infyn permit 10
#match ip address infyn
#set ip next-hop 10.50.0.1
Apply PBR on Interface
# interface G0/0
#ip policy route-map infyn
It could be done by other ways but this is the most easy that I know
Bye,
Raul from Peru
