missing pseudowire-class in 1801
lajoe.aal
Hi all,
I'm trying to configure client-initiated l2tp on my 1801 box, but I don't have pseudowire-class on the general config help menu...
Does anyone know why I don't have pseudowire-class in my global config?
[Cisco 1801/IOS 12.4(15)T7]
[image c180x-broadband-mz.124-15.T7.bin]
Thank you
LAJoe
6 Replies 6
Edison Ortiz
LAJoe,
You need Advanced IP Services, Advanced Enterprise Services, SP services or Enterprise Services feature set.
The IP broadband feature set is too basic for this service.
HTH,
__
Edison.
Hi Edison
I hear what you are saying.
However, when I look up my image in the CFN (Cisco Feature Navigator site - http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp) I see that "L2TP Client Initiated Tunneling" is listed for the Broadband feature set.
Any ideas? Maybe a typo?
LAJoe
LAJoe,
Thanks for posting the intended feature and you are right. I was looking under another feature and it provided the information I posted.
I will be curious if you were to upgrade to the recommended feature set and the command is available.
I don't have a 1800 router around so I can't test for you.
__
Edison.
I am trying to get the upgrade pack for my 1801 (FL1801-BB-AISK9= Cisco 1801 IP Broadband to Advanced IP Services Upgrade), so I should have the answer in a couple of days.
I will post here if this solves my problem.
Thank you again
LAJoe
jasoncoxlee
Was there ever a solution to this?
1841 running..
(C1841-ADVSECURITYK9-M), Version 15.1(4)M12a, RELEASE SOFTWARE (fc1)
Also tried (EnterpriseServices), same version.
Command either has been eliminated, or requires other config to be in place, it would seem.
