Mobile hotspot in Packet Tracer?
limey75
Hi Guys,
Not sure whether this the correct place to post this query, but I can't see a better place...
Is it possible to create a mobile hotspot (from a smartphone) in PT? I can't at present see a way of doing this. It looks like you can do wired USB-tethering, though.
Thanks!
Asemmoqbel
Packet tracer has limitations and it doesn't help much to create real labs with higher services such as mobile hotspot.
I recommend you to use GNS3 for this kind of Labs as it has many features and plus.
Best Regards
Asem
Asemmoqbel
Best Regards
Asem
Thanks, Asem!
You are Welcome ...
g5cisco
Hello all,
it is actually possible to use the PT mobile phone has an hotspot the virtual world of Packet Tracer.
You may want to look at the example bluetooth tethering.pkt. You will find in the latest PT 8.2.1 using the "Open Samples" and navigating to file:  1-Networking \ Wireless \ Bluetooth \ bluetooth tethering.pkt.
G5
