Create Port Channel on Cisco NCS 540 Router with Non-Cisco Switch
Cisco Support
We are going to aggregate two GIG ports of NCS router and connect to the Non -Cisco Layer 03 core switch stack. Please refer to the below mention diagram for more understanding
As per above diagram
Configuration already made on Cisco NCS 540 1 Router:
interface Bundle-Ether1
 description Link to HQ_LAN_CORE
 ipv4 address 172.16.7.161 255.255.255.248
interface GigabitEthernet0/0/0/18
 bundle id 1 mode active
interface GigabitEthernet0/0/0/19
NCS router has been configured in the above manner and link aggregation has been configured in the same manner in the non cisco switch. But after connecting the cables, the gig ports of the router are up, but the ports of the non-cisco switch are not up. That mean port channel in operational between NCS router and non-cisco switch
Please note:  aggregate port of the non-cisco switch is in switch port state, but the NCS router's gig port are not specify as switchports
What could be the issue, NCS router unable to aggregate their ports with layer 2 interface or if their any specific method to do that?
17 Replies 17
M02@rt37
Hello @Cisco Support,
The non Cisco L3 LAN-CORE Stack is configured in a cluster mode ? Equivalent of virtual domain or virtual chassis ?
Best regards
Yes we L3 LAN-Core is Configured as two switch cluster
can I see the config of PO in SW side?
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 2 provision ws-c2960s-48ts-l
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport access vlan 100
switchport mode access
interface FastEthernet0
no ip address
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface GigabitEthernet2/0/49
channel-group 1 mode active
interface GigabitEthernet2/0/50
interface GigabitEthernet2/0/51
interface GigabitEthernet2/0/52
interface Vlan1
no ip address
interface Vlan100
ip address 172.16.7.163 255.255.255.248
ip http server
ip http secure-server
sorry why you use bundle not port-channel ?
Can we use NCS 540 router port as switch port? if yes how can we do that?
As per the guideline of NCS router configuration it mentioned link aggregation following way:
Above method is working fine with another NCS 540 Router, but not working with Layer 2 Switch, so I want clarify that.
you have NCS bundle config as L3 router port connect to stack-SW PO config as L2 swithport with access vlan 100
from my view it must be work
I already try this with CSR1000 and it work (try using Portchannel not bundle)
may be double check show ip int brief and show interface status see if the SW & NCS add PO to it Database.
RP/0/RSP0/CPU0:Cisco-XR1#show lacp Bundle-ether xx <<- share this if you can
okay.. but how can I use port-channel instead of bundle in the NCS? coz as per the my reference i unable to find how to config port-channels on NCS instead of Bundles
correct I already check this point, IOS and IOS XE named it as port channel, IOS XE named it as bundle.
share
show etherchannel summary <<- in SW side
RP/0/RP0/CPU0:HQR01#show lacp bundle-Ether 1
Fri Jun 30 15:59:49.236 UTC
State: a - Port is marked as Aggregatable.
s - Port is Synchronized with peer.
c - Port is marked as Collecting.
d - Port is marked as Distributing.
A - Device is in Active mode.
F - Device requests PDUs from the peer at fast rate.
D - Port is using default values for partner information.
E - Information about partner has expired.
Bundle-Ether1
Port (rate) State Port ID Key System ID
Local
Gi0/0/0/18 1s a---A-D- 0x8000,0x0002 0x0001 0x8000,48-2e-72-16-e4-85
Partner 30s -----FD- 0x0000,0x0000 0x0000 0x0000,00-00-00-00-00-00
Gi0/0/0/19 1s a---A-D- 0x8000,0x0001 0x0001 0x8000,48-2e-72-16-e4-85
Port Receive Period Selection Mux A Churn P Churn
Local
Gi0/0/0/18 Defaulted Fast Unselect Detached Monitor Monitor
Gi0/0/0/19 Defaulted Fast Unselect Detached Monitor Monitor
Switch#show etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SD) LACP Gi2/0/49(D) Gi2/0/50(D)
in SW the PO is down
no shut for PO and it port member
Yes I already issued no shut command both gig interface but when i connects to the NCS the SW port is down
connect cable and no shut the port again.
Cisco Support
Yes Did it, but not working still port is not up
shutdown
Switch(config)#interface range gigabitEthernet 2/0/49-50
Switch(config-if-range)#shu
Switch(config-if-range)#shutdown
*Mar 1 01:01:48.561: %LINK-5-CHANGED: Interface GigabitEthernet2/0/49, changed state to administratively down
*Mar 1 01:01:48.572: %LINK-5-CHANGED: Interface GigabitEthernet2/0/50, changed state to administratively down
Switch(config-if-range)#no shu
Switch(config-if-range)#no shutdown
*Mar 1 01:02:34.856: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/49, changed state to down
*Mar 1 01:02:34.871: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/50, changed state to down
