Mutual redistribution loops
carl_townshend
Hi Guys
I remember seeing a good post and diagram how a loop caused by mutual redistribution between 2 routing protocols was caused and mitigated, had anyone got a good example of this with a diagram? I think it was stopped using tags or distribute lists.
Cheers
Carl
9 Replies 9
balaji.bandi
You can look : KB  - there are some examples provided
https://community.cisco.com/t5/networking-knowledge-base/tkb-p/4461-docs-network-infrastructure
One give example  with slides here : (hope if you look at the user posted have other examples also can be find in KB pages)
https://community.cisco.com/t5/networking-knowledge-base/routes-redistributions-slides/ta-p/4650866
BB
In production networks I would say that mutual redistribution is something to be avoided at almost any cost because it has so much disaster potential. I find that people think every router in a network needs every route, but that isn't the case. It needs to be able REACH everywhere, but it doesn't need every route. Looking at summarization instead is safer and more reliable.
You are 100 % right,
I think he study some Cisco Course not want to run it in real network
thanks
Hi there
What would the alternative be ? if we need to get routes between 2 different networks with different protocols, how can we get around it ?
also how would summarising solve it?
@carl_townshend wrote:
Hi there
Somewhat like what we often do for for the Internet.
You create a static, or statics, in each AS that covers the address block(s) used by the other AS, pointing to your egress link(s) to the other AS.  Those statics are redistributed into just their local AS.
Each AS would "know" of the address block(s) within the other AS, and how to reach it, but the two ASs do not share routes, i.e. there is no route redistribution between them.
This approach has advantages and disadvantages vs. mutual redistribution.
If you do go the mutual redistribution approach, as noted in other replies, you can tag routes redistributed into the other AS while excluding accepting routes with your tag(s) coming from the other AS.
one way of summary using static to Null0 to avoided mutual redistribution
R1
router ospf 100
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 100.0.0.0 0.0.0.255 area 0
network 200.0.0.0 0.0.0.255 area 0
R2
router eigrp 110
network 110.0.0.0 0.0.0.255
redistribute static metric 100 100 255 1 1500
router ospf 100
ip route 1.0.0.0 255.0.0.0 Null0
R4
router eigrp 110
network 210.0.0.0
D EX 1.0.0.0/8 [170/25628160] via 110.0.0.2, 00:01:33, FastEthernet2/1
110.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 110.0.0.0/24 is directly connected, FastEthernet2/1
L 110.0.0.4/32 is directly connected, FastEthernet2/1
210.0.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 210.0.0.0/24 is directly connected, FastEthernet3/1
L 210.0.0.4/32 is directly connected, FastEthernet3/1Screenshot (490).png
Hello
I would say the filtering on tags is a good option.
Example:   At the two distribtution points:
route-map ospf-into-eigrp deny 10
match tag 110
route-map ospf-into-eigrp pemit  99
set tag 110
route-map eigrp-into-ospf deny 10
match tag 170
route-map eigrp-into-ospf pemit 99
set tag 170
router ospf x
redstribute eigrp route-map eigrp-into-ospf subnets
router eigrp x
redstribute ospf route-map ospf-into-eigrp  metric 1 1 1 1 1
Kind Regards
Paul
Hi Paul
I use this method all the time in live networks and it works good
Rick
