NAT overlapping networks
m.sir
Level 7
Level 7
I have following question:
Connecting two remote sites both are 192.168.10.x i would like to NAT traffic following
site A: if communicate with site B is NATed to fe. 192.168.100.x (static NAT 192.168.10.8 is needed to be NATed always 192.168.100.8} and side B if communicate with site A is NATed to fe. 192.168.200.x (again static NAT 192.168.10.8 from B is NATed always to 192.168.200.8)....
Is possible also keep Internet NAT for both sites???
Thx
M.
gpulos
Level 8
Level 8
i would NAT both sides to the same subnet, ie:
sideA - 192.168.10.10 >>> 172.16.1.10/16
sideB - 192.168.10.10 >>> 172.16.2.10/16
and/or, you can use a NAT pool for non-static hosts.
this also eliminates the extra routing hop to get from 192.168.100.0/24 to 192.168.200.0/24.
