Need help learning QOS
ryel.dsouza
I'm finding learning QOS quite taxing & confussing. I would like to know which book will be suitable to understaning the concepts along with the configuration.
ariela
Level 4
Level 4
QoS is too generic ... your job are focused on IP based infrastructures, or maybe on MPLS as well? L2 or better L3? or are you interested on a generic point of view?
Andrea
just books where i get get things right such as cbwfq, dscp, cos, red, wred, etc on ip & mpls infrastruture.
thanks for your details.
Well, normally a good start point is the 'Cisco CD' (http://www.cisco.com/univercd).
For example:
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/12_4/qos_12_4_book.html
A good book, well detailed and good written (the autors are autenthic QoS gurus):
http://www.amazon.com/Deploying-MPLS-QoS-Multiservice-Networks/dp/0123705495
Andrea
Mark Yeates
Level 7
Level 7
Ryel,
I would also check out the QoS SRND guide. It has some very good reference material.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html
HTH,
Mark
