Layer 3 Cannot Ping next hop
kennylee88
Hello all,
  I need help here. I just set up two routers and two layer 3 switches. Can someone check my settings? I cannot ping over to 3.3.3.1 or vice versa. I attached the PKT file. Please rename it back to PKT from PNG.   I greatly greatly appreciated if some one can help me.  thx
@kennylee88 can you share the PPT you are trying after adding the static route.  and from where are you tring to ping? (which PC)
If you want to ping to 3.3.3.2, add below route in 2nd router.
#ip route 192.168.10.0 255.255.255.0 3.3.3.1
also check below link to get an good understanding how routing works.
https://www.ipxo.com/blog/network-routing/
Good luck
KB
8 Replies 8
marce1000
 - There are no attachments , may I also point you to : Community group for Packet Tracer project questions
  M.
Shoot sorry, ok i attached it.  Thanks for the reply.
kennylee88
Hello all,
  I need help here. I just set up two routers and two layer 3 switches. Can someone check my settings? I cannot ping over to 3.3.3.1 or vice versa. I attached the ZIP file . Please rename the extension form TXT to PKT.   I greatly greatly appreciate if someone could help me.  thx
        - FYI : Community group for Packet Tracer project questions
  M.
@kennylee88 hi, add below route in router0.
#ip route 192.168.10.0 255.255.255.0 192.168.30.2
Good luck
KB
Nope didnt work.. still cant ping over to 3..3.3.2
Good luck
KB
Yay got it! thx soo much.
Now i wanted to put a router between those 2 routers. How complicated is
that?
