Need Help to configuration 1905 router
kuldip.trivedi
Hello, anyone can you please help to configure my router for configure Internet line
my ip details
Ip pool 14.98.129.148/29
ip gateway 14.98.129.249
lan ip 14.98.129.251-254
subnet 255.255.255.248
wan ip 111.93.94.140/30
wan gateway 111.93.94.141
wan usable ip 111.93.94.142
subnet 255.255.255.252
balaji.bandi
Cisco docwiki have sample example for your kind of setup.
http://docwiki.cisco.com/wiki/NAT_failover_with_DUAL_ISP_on_a_router_Configuration_Example
change the interface and IP addresses, you it should work basic setup.
BB
Hello
my ip details
The Ip gateway of the ip pool is incorrect should be between 14.98.129.145-150
Also is the lan ip subnet so for them to be in the same network change the subnet mask to be a /25 = 255.255.255.128
Kind Regards
Paul
it looks like you got public IP address ranges for both LAN and WAN, is that right ? If that is the case, the config should look like below:
Building configuration...
Current configuration : 723 bytes
no service pad
hostname C1905
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
no ipv6 cef
ip source-route
ip cef
archive
log config
hidekeys
interface GigabitEthernet0/0
description LAN Interface
ip address 14.98.129.249 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description WAN Interface
ip address 111.93.94.142 255.255.255.252
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 111.93.94.141
no ip http server
control-plane
line con 0
line aux 0
line vty 0 3
login
exception data-corruption buffer truncate
scheduler allocate 20000 1000
end
