Need help with router rip and pinging different LANS
Spufferman
So for homework a homework exercise, I have 2 LANS and the goal is to be able to ping devices from 1 lan to the other. I'm trying to use router rip but it doesn't work.
Router 0
router rip
network 20.0.0.0
network 30.0.0.0
Router 1
router rip
network 30.0.0.0
network 172.16.3.0
But for some reason when I look at the config, it becomes:
network 30.0.0.0
network 172.16.0.0
Why does it automatically change to a 0 instead of the 3 I typed in. Because of it I cannot ping between different LANs
Also, how can I add extra information in the Logical Topology? I always see screenshots where the interfaces etc are visible, but I cant seem to find it in packet tracer nor google.
balaji.bandi
that is the normal behavior of RIPv1, if you using RIPv2 then it should work as expected.
I'm trying to use router rip but it doesn't work.  - what is not working even though it has supernet added, that should work.
can you post output - show run from both the router and also show IP route.
BB
it is normal, rip will view the network as classful not as classless,
now
for connectivity only check the defualt GW in host in each VLAN.
Martin L
You can attach your PT pkt file here (must be in a zip format).
Regards, ML
**Please Rate All Helpful Responses **
