Needing an Example of Cisco QOS for Zoom
randyclark
I need to apply QOS to my routers for ZOOM. I noticed on the ZOOM controller the DSCP ports are different. The default Zoom DSCP marking values are 56 for audio, 40 for video, and 40 for signaling. Would changing the following work?
From this....
class-map match-any VOICE
match dscp cs3
match ip dscp ef
class-map match-any VIDEO
match dscp cs4
match dscp af41
To this....
match dscp cs3
match ip
dscp ef56
match dscp cs4
match
dscp af40
Thanks for any advice in advance!
Hi Randy,
Please make the following corrections as there is no ef56 and af40 afaik.
match dscp cs3
match ip
dscp cs7
match dscp cs4
match
dscp cs5
If you are having only 56 for Voice and 40 for Video and Signaling, you do not need dscp cs3 and cs4. You can clean it up more as follows (assuming you are running only IPv4) :
match ip
dscp cs7
match ip
dscp cs5
HTH,
Meheretab
HTH,
Meheretab
balaji.bandi
As per the document, it is correct.
https://support.zoom.us/hc/en-us/articles/207368756-QoS-DSCP-Marking
make necessary changes and test and advise.
BB
Hi Randy,
match dscp cs3
match ip
dscp cs7
match dscp cs4
match
dscp cs5
match ip
dscp cs7
match ip
dscp cs5
HTH,
Meheretab
HTH,
Meheretab
Dennis Mink
on your QoS policing device (ASR, ISR, or whatever),
on the inbound interface, just re classify, SIP and RTP traffic through the ACL into ef and af41, this way you keep it conistent.
access list for instance:
access-list 100 permit udp any any range 16384 32767
access-list 100 permit tcp any any eq 5060
route-map classify_mark
 match ip address 100
 set ip precedence 5
interface Ethernet0/0
 ip address 10.10.10.1 255.255.255.0
 ip policy route-map classify_mark
Please remember to rate useful posts, by clicking on the stars below.
