Network drop down
deelant04
hi
i just change my router to a cisco 871 and it appear that my connection keep droping out every two days i lost all connection. i have to reboot the router then everything work fine again. Can somebody help me out there
5 Replies 5
paolo bevilacqua
Likely IOS bug, try to get access to a newer version.
hi
am a bit new on cisco can you please help me how to get the new IOS version and how to upload it onto the router
spremkumar
Level 9
Level 9
Which connection you are mentioning over here? Are you pointing out WAN or LAN or Wireless ?
regds
WAN
Assuming you have a default route statement, does it point to the interface or to the next hop's IP address? If the former, try the latter.
