Network routing
LincolnR
I created a Lo102 interface on router R1 ip address 100.110.102.1 255.255.255.0 to simulate a network behind it. I have a 172.21.1.0 / 24 network from a 701. vlan. I announced the 172.21.1.0 network via OSPF on R17 to R1.
# R17 # ospf 100 # router
summary-address 10.0.0.0 255.0.0.0
network 100.126.198.0 0.0.0.255 area 100
network 172.21.1.0 0.0.0.255 area 100
neighbor 100.126.198.238
R17 # sh ip route 172.21.1.0
Routing entry for 172.21.1.0/24
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 10.22.212.2
ip route 172.21.1.0 255.255.255.0 10.22.212.2
access-list 10 permit 172.21.1.0 0.0.0.255
access-list 20 permit 10.22.212.0 0.0.0.255
interface FastEthernet1 / 0
description To_R1
ip address 100.126.198.237 255.255.255.252
ip nat outside
ip ospf network point-to-point
FastEthernet0 / 0 interface
ip address 10.22.212.1 255.255.255.0
ip nat inside
I also created a static route for R1.
On R1 I announced the network 100.110.102.0
ospf 100 router
router-id 10.10.10.101
network 100.110.102.0 0.0.0.255 area 100
neighbor 100.126.198.237
I have a PC on the 172.21.1.10 network that cant ping the Lo102. What is missing to solve this problem?
I am setting up this lab to develop my knowledge in routing. In the future I will add an ASA behind the R17. My idea with this topology is to simulate a data center behind the R17 and arrive at a branch on the internet.
*********************R1*************************
router ospf 1
router ospf 100
router bgp 500
bgp log-neighbor-changes
bgp bestpath compare-routerid
network 1.1.1.1 mask 255.255.255.255
network 172.21.1.0 mask 255.255.255.0
neighbor 192.168.12.2 remote-as 500
neighbor 192.168.13.3 remote-as 500
maximum-paths ibgp 2
Hello
Can you clarify where the device that hosts this Loopback interface is located?
If it’s on the inside of a natted network, then you won’t be able to reach it externally unless it has a valid inside global address relating to it.
Also note by default opsf loopback interfaces are advertised as host /32 unless you change the ospf interface mode of the loopback however this shouldn’t negate that interface from being advertised within ospf.
Int  Loopback0
Kind Regards
Paul
8 Replies 8
balaji.bandi
Not sure your topology how it looks like :
but why you have static route - ip route 172.21.1.0 255.255.255.0 10.22.212.2 (this take precedence - so remove it)
If R17 Announcing route to R1 - R1 should see the routes show io route and learn routes (if the OSPF neighbour relation up and running)
on R1
why you are announcing same route in BGP :
router bgp 500
 no network 172.21.1.0 mask 255.255.255.0
if you like to learn the route to announce via BGP you can redistribute OSPF learn routes., but one step at a time, fix your Loopback interface reachability fist.
BB
Below is part of my laboratory.
The first objective:
The network 172.21.1.0/24 is able to reach the network 100.110.102.0 it behind the R1. And ping the Lo102 100.110.102.1 on R1.
TESTs
 PC--> Lo102.
C:\Documents and Settings\user>tracert 100.110.102.1
1 2 ms 2 ms 2 ms 172.21.1.1
2 18 ms 17ms 16 ms 10.22.212.1 <<--R17-INTERFACE F0/0
3 * * * Request timed out.
When I remove the ip route 172.21.1.0 255.255.255.0 10.22.212.2. The packet with destination IP address 100.110.102.1 not arrive R17-INTERFACE F0/0.
2 * * * Request timed out.
The packet with destination interface Lo102 100.110.102.1
R17#ping 100.110.102.1
Sending 5, 100-byte ICMP Echos to 100.110.102.1, timeout is 2 seconds:
R1#ping 10.22.212.1 <<--R17 interface f0/0 inside
Sending 5, 100-byte ICMP Echos to 10.22.212.1, timeout is 2 seconds:
*****************R1**************************
I was announcing the 172.21.1.0 mask 255.255.255.0 network in BGP.
!I removed this configuration as requested.!
R1#
bgp 500 router
R1#show run
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Loopback102
interface Loopback10001
description Router-id OSPF100
ip address 10.10.10.101 255.255.255.255
interface FastEthernet0/0
description F0/1_R2
ip address 192.168.12.1 255.255.255.0
ip ospf 1 area 0
duplex full
interface FastEthernet1/0
description F0/0_R3
ip address 192.168.13.1 255.255.255.0
ip ospf 1 area 0
duplex full
interface FastEthernet2/0
description MPLS OI
ip address 100.126.198.238 255.255.255.252
duplex full
router ospf 1
router ospf 100
router bgp 500
************R17**************
The Router R17 receives OSPF information about 100.110.102.1/32.
R17#sh ip route
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.22.212.0/24 is directly connected, FastEthernet0/0
L 10.22.212.1/32 is directly connected, FastEthernet0/0
100.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
O 100.110.102.1/32
[110/2] via 100.126.198.238, 01:12:17, FastEthernet1/0
C 100.126.198.236/30 is directly connected, FastEthernet1/0
L 100.126.198.237/32 is directly connected, FastEthernet1/0
126.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 126.1.1.0/24 is directly connected, Loopback3
L 126.1.1.1/32 is directly connected, Loopback3
130.100.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 130.100.200.0/24 is directly connected, Loopback2
L 130.100.200.1/32 is directly connected, Loopback2
I have configured a NAT on the R17 for the network 172.21.1.0/24.
R17#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
--- 172.21.1.6 172.21.1.10 --- ---
interface Loopback2
ip address 130.100.200.1 255.255.255.0
interface Loopback3
ip address 126.1.1.1 255.255.255.0
ip nat inside
duplex full
ip nat outside
duplex full
no ip address
shutdown
duplex full
router ospf 100
network 10.22.212.0 0.0.0.255 area 100
ip nat pool servers 172.21.1.6 172.21.1.253 netmask 255.255.255.0
ip nat inside source list 10 pool servers
ip forward-protocol nd
no ip http server
no ip http secure-server
Could the problem be with NAT?
Martin L
I would start TS with trace to see see where it stops (or how far it goes); And if you have A real PC (not virtual), check PC firewall.
also, see show ip route 100.110.102.1 t check if it's missing somewhere.  why you have static route?
Regards, ML
**Please Rate All Helpful Responses **
behind the *R1*. And ping the Lo102 100.110.102.1 on *R1.*
TESTs
PC -> Lo102.
2 18 ms 17ms 16 ms 10.22.212.1 *<<--R17-INTERFACE F0/0*
When I remove the *ip route* *172.21.1.0 255.255.255.0 10.22.212.2*. The
packet with destination IP address 100.110.102.1 not arrive *R17-INTERFACE
F0/0.*
The packet with destination interface Lo102 100.110.102.1 from *R17.*
*R17#*ping 100.110.102.1
*R1#*ping 10.22.212.1 *<<--R17 interface f0/0 inside*
R1#
bgp 500 router
R1#show run
interface Loopback0
description F0/1_R2
ip ospf 1 area 0
duplex full
description F0/0_R3
ip ospf 1 area 0
duplex full
description MPLS OI
duplex full
router ospf 1
router ospf 100
router bgp 500
*************R17***************
The Router R17* receives OSPF information about 100.110.102.1/32
R17#sh ip route
O 100.110.102.1/32
interface Loopback2
interface Loopback3
ip nat inside
duplex full
ip nat outside
duplex full
router ospf 100
no ip http server
*Could the problem be with NAT?*
Martin.
It lab is created in EVE.
Hello
Int  Loopback0
Kind Regards
Paul
TESTs
PC -> Lo102.
F0/0.*
R1#
bgp 500 router
R1#show run
interface Loopback0
description F0/1_R2
ip ospf 1 area 0
duplex full
description F0/0_R3
ip ospf 1 area 0
duplex full
description MPLS OI
duplex full
router ospf 1
router ospf 100
router bgp 500
R17#sh ip route
O 100.110.102.1/32
interface Loopback2
interface Loopback3
ip nat inside
duplex full
ip nat outside
duplex full
router ospf 100
no ip http server
Hello
>It's EVE-NG Lab, The loopback behind R1. I posted of the running.
Int  Loopback0
 Paul, It's lab on EVE-NG.
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
TESTs
The PC Tracert for Lo102.
R1#
bgp 500 router
R1#show run
interface Loopback0
description F0/1_R2
ip ospf 1 area 0
duplex full
description F0/0_R3
ip ospf 1 area 0
duplex full
description MPLS OI
duplex full
router ospf 1
router ospf 100
router bgp 500
R17#sh ip route
O 100.110.102.1/32
interface Loopback2
interface Loopback3
ip nat inside
duplex full
ip nat outside
duplex full
no ip address
shutdown
duplex full
router ospf 100
no ip http server
