No internet for Clients C1111
murmucka
Hi guys,
router connects successfully to the internet, i also can ping WAN destination from CLI. But no internet for clients on Ethernet POrts.
Current configuration : 5787 bytes
! Last configuration change at 07:58:19 UTC Fri Nov 12 2021
version 16.9
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname GW-MURMUCKA-01
boot-start-marker
boot system flash bootflash:c1100-universalk9_ias.16.09.05.SPA.bin
boot-end-marker
enable secret 5 xxx
enable password 7 xxx
no aaa new-model
clock timezone UTC 1 0
ip nbar http-services
ip name-server 8.8.8.8
ip dhcp excluded-address 10.0.10.1 10.0.10.99
ip dhcp excluded-address 10.0.20.1 10.0.20.99
ip dhcp excluded-address 10.0.99.1 10.0.99.99
ip dhcp pool ClientPrinter
network 10.0.10.0 255.255.255.0
default-router 10.0.10.2
dns-server 8.8.8.8
ip dhcp pool IoT
network 10.0.20.0 255.255.255.0
default-router 10.0.20.2
dns-server 8.8.8.8
ip dhcp pool ManagementNetwork
network 10.0.99.0 255.255.255.0
default-router 10.0.99.2
dns-server 8.8.8.8
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-1281955900
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1281955900
revocation-check none
rsakeypair TP-self-signed-1281955900
crypto pki certificate chain TP-self-signed-1281955900
certificate self-signed 01
quit
license udi pid C1111-4P sn xxx
no license smart enable
diagnostic bootup level minimal
username admin privilege 15 secret 9 xxx
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
description Ace Telecom
no ip address
ip mtu 1452
ip nbar protocol-discovery
ip nat outside
ip tcp adjust-mss 1412
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
description Link to CoreSwitch
switchport trunk native vlan 99
switchport mode trunk
spanning-tree portfast trunk
interface GigabitEthernet0/1/1
description ClientPrinter
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/1/2
description IoT
switchport access vlan 20
interface GigabitEthernet0/1/3
description Management
switchport access vlan 99
interface Vlan1
no ip address
shutdown
interface Vlan10
description *** ClientPrinter ***
ip address 10.0.10.2 255.255.255.0
ip nat inside
interface Vlan20
description *** IoT ***
ip address 10.0.20.2 255.255.255.0
ip nat inside
interface Vlan99
description *** Management ***
ip address 10.0.99.2 255.255.255.0
ip nat inside
interface Dialer1
mtu 1480
ip address negotiated
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp mtu adaptive
ppp authentication pap callin
ppp pap sent-username user password 7 password
ppp ipcp dns request
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 11 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 11 remark define internal networks
access-list 11 permit 10.0.10.0 0.0.0.255
access-list 11 permit 10.0.20.0 0.0.0.255
access-list 11 permit 10.0.99.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
password 7 xxx
login
length 0
end
Georg Pauwen
make the changes marked in bold to your configuration:
version 16.9
boot-start-marker
boot-end-marker
enable secret 5 xxx
no aaa new-model
dns-server 8.8.8.8
ip dhcp pool IoT
dns-server 8.8.8.8
dns-server 8.8.8.8
certificate self-signed 01...
quit
redundancy
mode none
no ip address
ip mtu 1452
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
description IoT
interface Vlan1
no ip address
shutdown
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
interface Vlan99
ip nat inside
interface Dialer1
mtu 1480
--> ip nat outside
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
ppp mtu adaptive
ip http server
--> ip nat inside source list 11 interface Dialer1 overload
control-plane
line con 0
stopbits 1
line vty 0 4
password 7 xxx
login
length 0
end
5 Replies 5
balaji.bandi
Let's try below : ( what kind of clients ? what IP clients get ?) from client are you able to ping gateway if yes ttry below ?;
no ip nat inside source list 11 interface GigabitEthernet0/0/0 overload
BB
Hi, i just test the connection on Port GiEth0/1/1 (VLAN10)
Client is a PC, setting: DHCP. Client receive the proper IP 10.0.10.100 from ClientPrinter Pool, with the right gateway (10.0.10.2, and DNS 8.8.8.8)
But no internet on this PC. Ping the gateway works.
I changed the config to the suggested, without success. There is only internet from Cisco CLI
sorry missed the point on
interface Dialer1
 ip nat outside
BB
Georg Pauwen
version 16.9
boot-start-marker
boot-end-marker
enable secret 5 xxx
no aaa new-model
dns-server 8.8.8.8
ip dhcp pool IoT
dns-server 8.8.8.8
dns-server 8.8.8.8
quit
redundancy
mode none
no ip address
ip mtu 1452
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
description IoT
interface Vlan1
no ip address
shutdown
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
interface Vlan99
ip nat inside
interface Dialer1
mtu 1480
--> ip nat outside
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
ppp mtu adaptive
ip http server
control-plane
line con 0
stopbits 1
line vty 0 4
password 7 xxx
login
length 0
end
murmucka
Thank you guys, awesome, it works
