06-12-2020 10:06 AM
I have DMVPN working on 7 routers all are 4331 with 16.9.5. I am using NHRP but not crytop
All is working well, But when I try to "Show DMVPN" I get invalid input after the d
I ideas?
Again DMVPN is work with a dynamic tunnel spoke to spoke when needed, just no sh dmvpm.
Thank you
06-12-2020 01:46 PM
do you see anything with:
show ip nhrp nhs
06-15-2020 07:36 AM
nhrp Registration Timer: 20 Sec
06-12-2020 11:26 PM
What is the output you are getting? Can u post here?
I think you will get something like:
Router# show dmvpn
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
N - NATed, L - Local, X - No Socket
# Ent --> Number of NHRP entries with same NBMA peer
! The line below indicates that the sessions are being displayed for Tunnel1.
! Tunnel1 is acting as a spoke and is a peer with three other NBMA peers.
Tunnel1, Type: Spoke, NBMA Peers: 3,
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
2 192.0.x.x 192.0.2.116 IKE 3w0d D
1 192.0.x.x 192.0.2.11 NHRP 02:40:51 S
1 192.0.x.x 192.0.2.10 UP 3w0d S
Tunnel2, Type: Spoke, NBMA Peers: 1,
1 192.0.x.x 192.0.2.171 IKE never S
06-15-2020 07:34 AM
I got get invalid input after the d
#sh dmvpn
"invalid input detected at '^'
06-16-2020 12:10 AM
What about the license? You might need a Security license.
01-06-2023 07:03 AM
did you ever get this sorted???? I am having the exact same issue under similar circumstances
01-06-2023 09:32 AM
Hello @pboynton1
Suggest create your own post so it can be troubleshooted , appending the outpout of show version to it
01-06-2023 08:01 AM
try and toggle 'ip cef':
4331(config)#no ip cef
4331(config)#ip cef
01-12-2023 05:57 AM
like Deepak Kumar said , you need check your license , DMVPN on IOS-XE based router need Security license or higher
