No traffice on GRE Tunnel
faamin011
Cisco 3750x (IP Services)
interface Tunnel0
description " /\/\/\/\ XXX /\/\/\/\ "
bandwidth 256
ip flow ingress
ip address 192.168.1.1 255.255.255.252
keepalive 5 3
tunnel source 10.100.100.1
tunnel destination 10.100.100.2
end
interface GigabitEthernet1/0/24
description """XXX"""
no switchport
ip address 10.100.100.1 255.255.255.252
router ospf 1
  network 10.50.50.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.3 area 0
sh int tun 0
Output queue: 0/0 (size/max)
sh int gi 1/0/24
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 1000 bits/sec, 1 packets/sec
Why traffic is not travelling from tun 0
11 Replies 11
gaurav bhardwaj
send the full configuration both side
cadet alain
Which traffic ?
Regards.
Alain
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
3650/3750 series do not support tunnel interfaces (at least through 12.5[55]).
See
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swuncli.html#wp1021184
Rolf Fischer
Level 9
Level 9
Looks like you are "tunneling" a directly connected neighbor on network 10.100.100.0/30.
interface Tunnel0
This doesn't make sense because the physical connection will be the prefered one.
Taken from https://supportforums.cisco.com/docs/DOC-15948:
"Recursive routes
GRE tunnel has better metric over physical link as they are directly connected
Rolf
shamax_1983
Level 3
Level 3
Hi Fahad,
Yes as Rolf explained it wouldn't send traffic through the tunnel because you have a connected subnet.
you can simply verify this by looking at your routing table and check which interface is shown as the nexthop for the interrested network.
If you want to force traffic over the tunnel for any specific network, remove that from the OSPF and have static routes pointing the tunnel.
Please rate this post if you find it helpful.
Shamal
On closer inspection I noticed that network 10.100.100.0/30 seems not to run OSPF anyway, so I've to correct my previous post regarding recursive routing.
I assume, an adjacency has been established?
R1#show ip ospf interface tunnel 0
Tunnel0 is up, line protocol is up
Internet Address 192.168.1.1/30, Area 0
Process ID 1, Router ID 1.1.1.1, Network Type POINT_TO_POINT, Cost: 11111
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
Neighbor Count is 1, Adjacent neighbor count is 1
Adjacent with neighbor 2.2.2.2
Suppress hello for 0 neighbor(s)
If so, at least control traffic should be send across Tunnel0 (among keepalives).
R1#show ip ospf traffic | beg Tunnel0
Interface Tunnel0
OSPF packets received/sent
Invalid  Hellos   DB-des   LS-req   LS-upd   LS-ack   Total
Rx: 0        135      2        1        1        2        141
Tx: 0        138      3        0        3        1        145
Rolf
P.S.: Are you just playing around or what do you want to achieve with this setup?
We are running huge infrastructure around 200 nodes on similar gre configuration and found no issue. Right now we have procured new 3750x 24SE (12.2 (58) SE2) which seems no traffice on tunnel . its new configuration for new node..
As 10.100.100.0 is not advertised on ospf then it should be route via tunnel but whenever i generate traffic by only generating icmp packets towards destination then traffice comes on giga but not on tunnel, as shown above.
Although ospf neighbourship has been establised via tunnel but don't know why traffic not touching there.
The configuration that you have posted looks appropriate and I do not see any particular issues with it.
You have posted output of show commands about the interfaces but not about OSPF. It would help if you could post the output of show ip ospf interface from the switch to verify that OSPF is correctly running on the interface, and the output os show ip ospf neighbor to verify that OSPF is successfully establishing a neighbor relationship.
Assuming that those look correct it would then be helpful if you post the output of show ip route so that we can see what routes are advertised via OSPF via the tunnel.
Rick
Rick
I have replaced ospf with static routing, it's ok in lab, will apply in production and let u aware
It would seem to me that this would work with /32 subsets on the physical interfaces but making them /30's causes the issue.
EDIT: Well it would work if the .2 address is physically the next hop but then why the GRE tunnel? Planning on applying encryption or something?
Hello Fared,
Joseph is correct:
The General Routing Encapsulation (GRE) tunnel is not supported by the Cisco Catalyst 3750 Series Switches. Even though this feature can be configured with CLI, the packets can be neither switched by hardware, nor by software, which increases the CPU utilization.
Note: Only Distance Vector Multicast Routing Protocol (DVMRP) tunnel interfaces are supported for multicast routing in the Catalyst 3750. Even for this, packets cannot be switched with hardware. The packets routed through this tunnel must be switched through software. The larger number of packets forwarded through this tunnel increases CPU utilization.
There is no workaround for this problem. This is a hardware limitation in the Catalyst 3750 Series Switches.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00807213f5.shtml
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
