Open port outgoing and incoming Cisco router
papathimiu
Hi everyone
I am having a problem with the following scenario.
I have a small server at home. I have configured the NAT and I can connect to the server from the WAN. There are two special ports which I need to connect to from outside and the server need to connect to some service provider (Not the ISP). Lets say port: 2064 and 2065.
I have the following on the router:
interface Dialer1
ip nat outside
interface GigabitEthernet0/1
ip address 192.168.2.10 255.255.255.0
ip nat inside
ip policy route-map HTTP_NEXTHOP
ip nat inside source static tcp 192.168.2.30 2064 142.115.23.152 2064 extendable
ip nat inside source static tcp 192.168.2.30 2065 142.115.23.152 2065 extendable
ip nat inside destination list HTTP pool 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip access-list extended HTTP
permit tcp any any eq 2064
permit tcp any any eq 2065
route-map HTTP_NEXTHOP permit 10
match ip address HTTP
set ip next-hop 192.168.2.30
I still cannot outbound on those two ports.
Any ideas would be greatly appreciated.
balaji.bandi
Do you have generic outbound NAT Traffic ACL rule ? can you post full configuration.
BB
Hi balaji
Thank you for the reply.
I have the Nat rule and the ACL in place. I think is properly done.
Maybe I am missing something on it.
papathimiu
Webserver#show run
Building configuration...
Current configuration : 5240 bytes
! Last configuration change at 22:45:47 UTC Wed Jul 22 2020
version 15.2
service password-encryption
hostname Webserver
no ip domain lookup
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Wan-Interface
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 10
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 10
ppp authentication pap callin
ppp ipcp route default
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool 1 192.168.2.30 192.168.2.30 netmask 255.255.255.0 type rotary
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.2.30 80 interface Dialer1 80
ip nat inside source static tcp 192.168.2.30 53 interface Dialer1 53
ip nat inside source static udp 192.168.2.30 53 interface Dialer1 53
ip nat inside source static tcp 192.168.2.30 2086 interface Dialer1 2064
ip nat inside source static tcp 192.168.2.30 2087 interface Dialer1 2065
ip nat inside destination list 101 pool 1
ip route 0.0.0.0 0.0.0.0 Dialer1
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq domain
permit udp any any eq domain
permit tcp any any
permit udp any any
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 101 permit tcp any any eq 2064
access-list 101 permit tcp any any eq 2065
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input telnet
scheduler allocate 20000 1000
end
Hello
I see you have specifed  routed public ip addressing in your PAT entries, Can you confrim if this addressing is allocated to your wan rtr?
Also I would say the following isnt required:
no ip nat pool 1 192.168.2.30 192.168.2.30 netmask 255.255.255.0 type rotary
no ip nat inside destination list 101 pool 1
no ip nat inside destination list HTTP pool 1
no route-map HTTP_NEXTHOP
Kind Regards
Paul
