OSPF (ASBR)
kian_hong2000
I read from the book that ASBR is used to join different routing domain.
However, i notice that there is a router in my company used only ospf but receive LSA Type 1, 2, 3,4 and 5 (External) in the database.
However this router is consider ASBR when i issue "Show ip protocols"
What is the theory behind? Or can i say if the router is receiving LSA type 5, it is consider a ASBR router. I am confusing now. Thanks!
Richard Burts
Kianhong
Receiving LSA type 5 does not qualify a router as an ASBR. An ASBR generates type 5 LSA and not receives them.
Perhaps it would help us to understand the situation and to give you better answers if you would post the output of show ip ospf and of show ip protocol from that router.
Rick
Rick
A5# sh ip protocols
Routing Protocol is "ospf 1"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Router ID 172.16.20.10
It is an autonomous system boundary router
Redistributing External Routes from,
connected, includes subnets in redistribution
static, includes subnets in redistribution
Number of areas in this router is 1. 1 normal 0 stub 0 nssa
Address Summarization:
Maximum path: 4
Routing for Networks:
10.152.0.0 0.0.3.255 area 0
Reference bandwidth unit is 100 mbps
Passive Interface(s):
Vlan30
Routing Information Sources:
Gateway Distance Last Update
10.1.3.8 110 2w4d
10.1.2.9 110 3w5d
10.1.2.3 110 3w5d
10.1.3.3 110 3w5d
10.1.3.5 110 2w4d
10.1.3.6 110 2w4d
10.1.3.7 110 2w4d
1.1.1.17 110 22:00:15
172.16.20.10 110 6w3d
166.xx.xx.x 110 21:56:12
Distance: (default is 110)
A5#sh ip ospf
Routing Process "ospf 1" with ID 172.16.20.10
Start time: 12w4d, Time elapsed: 29w0d
Supports only single TOS(TOS0) routes
Supports opaque LSA
Supports Link-local Signaling (LLS)
Supports area transit capability
Router is not originating router-LSAs with maximum metric
Initial SPF schedule delay 5000 msecs
Minimum hold time between two consecutive SPFs 10000 msecs
Maximum wait time between two consecutive SPFs 10000 msecs
Incremental-SPF disabled
Minimum LSA interval 5 secs
Minimum LSA arrival 1000 msecs
LSA group pacing timer 240 secs
Interface flood pacing timer 33 msecs
Retransmission pacing timer 66 msecs
Number of external LSA 563. Checksum Sum 0x57CA8E3
Number of opaque AS LSA 0. Checksum Sum 0x000000
Number of DCbitless external and opaque AS LSA 7
Number of DoNotAge external and opaque AS LSA 0
Number of areas transit capable is 0
External flood list length 0
IETF NSF helper support enabled
Cisco NSF helper support enabled
Area BACKBONE(0)
Number of interfaces in this area is 2
Area has no authentication
SPF algorithm last executed 21:55:21.744 ago
SPF algorithm executed 354 times
Area ranges are
Number of LSA 16. Checksum Sum 0x232DA0
Number of opaque link LSA 0. Checksum Sum 0x000000
Number of DCbitless LSA 3
Number of indication LSA 0
Number of DoNotAge LSA 0
Flood list length 0
Hi Kianhong,
Following the information that you have recently posted , you are redistributing the static and connected routes into OSPF via this router. Because you are injecting the connected and static routes which are currently not within the OSPF domain ( some connected interfaces might be included in OSPF domain by enabling OSPF on them but static routes are not included ), you are injecting new routes to OSPF. This process is just like redistributing from another routing protocol domain, so the router acts like an ABSR and indicates its position on the outputs .
HTH,
Kerem
kian
kindly check under ospf process, you are deifnately using the redistribute static.
regards
shivlu jain
