OSPF help
Jeza-925
Hi all,
Can somebody please help me understand what is being advertised from this router over ospf:
interface Loopback0
description ConnectionToBranch
ip address 10.16.7.254 255.255.255.255
router ospf 1
redistribute static subnets route-map STATIC-PERMIT
passive-interface Loopback0
network 10.16.7.254 0.0.0.0 area 0
network 10.255.0.0 0.0.255.255 area 0
distribute-list route-map LISTA in
ip route 0.0.0.0 0.0.0.0 10.16.253.1 130
ip route 10.0.253.2 255.255.255.255 10.16.253.1
ip route 10.16.0.0 255.255.0.0 10.16.253.1
ip route 10.16.0.0 255.255.248.0 10.16.252.1
ip route 10.30.254.2 255.255.255.255 10.16.253.1
ip prefix-list LISTA seq 10 permit 0.0.0.0/0
ip prefix-list LISTA seq 20 permit 10.30.7.254/32
ip prefix-list STATIC seq 10 permit 10.16.0.0/21
route-map STATIC-PERMIT permit 10
match ip address prefix-list STATIC
route-map LISTA permit 10
match ip address prefix-list LISTA
If I understand this correctly distribute-list is allowing everything to route table with permit 0.0.0.0/0? What is advertised to other router? What is the purpose of STATIC commands?
Thanks in advance.
balaji.bandi
we are not sure full topology you working on, based on this information -
distribute-list route-map LISTA in   - you filtering the routes coming in
redistribute static subnets route-map STATIC-PERMIT  - this matches your  -ip prefix-list STATIC seq 10 permit 10.16.0.0/21
One of a good example explained here :
https://lpmazariegos.com/2016/04/01/ospf-filtering-part-iii/
BB
Martin L
not exactly, permit 0.0.0.0/0 without le or ge 32 means only default route.  To permit All prefixes you need permit 0.0.0.0/0 le 32.
So, it looks like distribute-list route-map LISTA in permits default route o.o.o.o/o and 10.30.7.254/32; none others are permitted because of missing permit any (0.0.0.0/0 le 32) at the end of statement.
And, redistribute static  subnets  means redistribute static routes into osfp - you have 5 - but since there is route map attached ospf lets only 10.16.0.0/21 to be redistributed. STATIC seq 10 permit 10.16.0.0/21
Regards, ML
**Please Rate All Helpful Responses **
