why can't i bring this interface back up?
Switch(config-if)#shut
%LINK-5-CHANGED: Interface FastEthernet0/4, changed state to administratively down
Switch(config-if)#
Switch(config-if)#no shut
%LINK-5-CHANGED: Interface FastEthernet0/4, changed state to down
Switch(config-if)#
Switch(config-if)#
Switch(config-if)#do sh ip int brief
FastEthernet0/1 unassigned YES manual up up
FastEthernet0/2 unassigned YES manual up up
FastEthernet0/3 unassigned YES manual up up
FastEthernet0/4 unassigned YES manual down down
12 Replies 12
check if your port connected to working network device from other side with working cable.
Good luck
KB
Yep, got a PC on the other side of it
C:\>ipconfig /all
Bluetooth Connection:(default port)
Connection-specific DNS Suffix..:
Physical Address................: 0005.5E16.CC05
Link-local IPv6 Address.........: ::
IPv6 Address....................: ::
IPv4 Address....................: 0.0.0.0
Subnet Mask.....................: 0.0.0.0
Default Gateway.................: ::
0.0.0.0
DHCP Servers....................: 0.0.0.0
DHCPv6 IAID.....................:
DHCPv6 Client DUID..............: 00-01-00-01-20-AE-BB-AE-00-10-11-15-32-85
DNS Servers.....................: ::
0.0.0.0
FastEthernet0 Connection:
Physical Address................: 0010.1115.3285
Link-local IPv6 Address.........: FE80::210:11FF:FE15:3285
IPv4 Address....................: 192.168.10.4
Subnet Mask.....................: 255.255.255.0
0.0.0.0
0.0.0.0
is switch link light blinking?
share #show interface fa 0/4 output
Good luck
KB
Switch#sh int fa0/4
FastEthernet0/4 is down, line protocol is down (disabled)
Hardware is Lance, address is 0001.9615.6604 (bia 0001.9615.6604)
BW 100000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input 00:00:08, output 00:00:05, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
956 packets input, 193351 bytes, 0 no buffer
Received 956 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 0 multicast, 0 pause input
2357 packets output, 263570 bytes, 0 underruns
0 output errors, 0 collisions, 10 interface resets
0 lost carrier, 0 no carrier
Check speed and duplex settings.
Jon
#hi, these were okay.  I disconnected and connected again and voila! Port came up?
Show interface status
When port is down
Share here
Looks like for me Duplex issue, check, is this half or full duplex. ( change combination)
BB
share output of
#show run interface fa 0/4
also
make sure port speeds and duplex are matching both sides
Good luck
KB
this command did not work
can you share what you tried and output of #Show run ?
Good luck
KB
 "show int status" is a better command for you as this is a layer 2 interface.
If on the "show int status" the output is notconnect then you may have a cable problem of a hardware problem.
 You also run
test cable-diagnostics tdr interface gx/X
Use 'show cable-diagnostics tdr'
to see the result
