OSPF routing Help
Ayodeji Okanlawon
Guys,
I am not a traditional routing and switching guy, I am a core voice specialist. However I have a little project as follows.
I have 4 sites connected via frame-realy.
HQ1, HQ2, SIte a and site b.
The Frame-relay WAN connection is in place and I am using OSPF to do my dynamic routing.
here is my challenge.
HQ1 and HQ2 are in the same LAN, i.e 172.16.1.1 and 172.16.1.2. But in my OSPF database (from sh ip route) I can only see the network for HQ1 been advertised through the HQ1 serial interface. I am using HSRP between HQ1 and HQ2 Lan so that I have resiliency and redundancy. When HQ1 serial goes down, I can nolonger reach the HQ, even though a path is available through HQ2.
Is there a way to make osfp advertise both HQ1 and HQ2 Lan network through different interfaces.? This way when HQ1 serial goes down, I can still reach the 172.16.1.0 network through HQ2.
Many thanks
Please rate all useful posts
Let us now leave HQ1.
Do you have OSPF adjacency between branches and HQ2.   Who is the DR and BDR on this Segment.
Do you have fram relay mapping for HQ2 from the branches as well
Can you post (Sh ip ospf neighbor) from the branches as well as the HQ routers.
Note:
I can see your frame relay is fully meshed Topology with Network as a broadcast type.
Mohamed
6 Replies 6
Mohamed Sobair
Level 7
Level 7
You just need to run OSPF in the LAN segment between HQ1 and HQ2, this way if any of the routers WAN OSPF interfaces fail, other branches would know how to reach both routers.
Mohamed
Muhammed,
This is exactly what I have done.
Hq1# int fa0/0, ip add 172.16.1.1/24
router ospf 1
network 172.16.1.0 0.0.0.255
hq2#int fa0/0, ip add 172.16.1.2/24
router ospf1
network
However the LAN route is only been advertised through Hq1's serial interface. There is no entry for hq2. Hence when hq1 goes down, the 172.16.1.0 subnet is unreachable
Mohamed Sobair
Level 7
Level 7
This shouldnt be, if both serial Interfaces of both routers HQ1 and HQ2 participate in OSPF, the OSPF database of the branches should include two possible paths to Network 172.16.1.0/24 via HQ1 and HQ2. and the one with the least metric will be installed in the routing table.
If this is the case, Then I would look at my OSPF config on all routers, pleas post your diagram if you have it with the current config so I can look at it.
Mohamed
Muhammed, here are the relevant configs. Attached is the network diagram.
hq1
interface FastEthernet0/1
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
standby 1 ip 172.16.1.3
standby 1 priority 105
standby 1 preempt
standby 1 track Serial0/2/0
interface Serial0/1/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface Serial0/2/0
ip address 10.2.1.1 255.255.255.0
encapsulation frame-relay
ip ospf network broadcast
ip ospf mtu-ignore
frame-relay map ip 10.2.1.2 711 broadcast  frame-relay map ip 10.2.1.3 710 broadcast  frame-relay map ip 10.2.1.4 712 broadcast  frame-relay lmi-type ansi !
interface Serial0/2/1
no ip address
shutdown
clock rate 2000000
router ospf 1
log-adjacency-changes
area 1 virtual-link 172.16.1.1
area 1 virtual-link 10.2.1.1
network 10.2.1.0 0.0.0.255 area 0
network 10.34.255.0 0.0.0.255 area 0
network 172.16.1.0 0.0.0.255 area 0
Gateway of last resort is 10.34.255.10 to network 0.0.0.0
     172.16.0.0/24 is subnetted, 2 subnets
C       172.16.1.0 is directly connected, FastEthernet0/1
O       172.16.2.0 [110/65] via 10.2.1.3, 02:07:06, Serial0/2/0
     10.0.0.0/24 is subnetted, 4 subnets
C       10.2.1.0 is directly connected, Serial0/2/0
C       10.66.10.0 is directly connected, FastEthernet0/0.41
O       10.10.101.0 [110/65] via 10.2.1.3, 02:07:06, Serial0/2/0
C       10.34.255.0 is directly connected, FastEthernet0/0.39
O    192.168.1.0/24 [110/65] via 10.2.1.4, 02:07:06, Serial0/2/0
S*   0.0.0.0/0 [1/0] via 10.34.255.10
---------------hq 2--------------------
interface FastEthernet0/0
ip address 172.16.1.2 255.255.255.0
duplex auto
speed auto
standby 1 priority 110
standby 1 preempt
interface Serial0/0/0
ip address 10.2.1.2 255.255.255.0
ip ospf mtu-ignore
no fair-queue
frame-relay traffic-shaping
frame-relay map ip 10.1.2.4 721
frame-relay map ip 10.1.2.3 722
frame-relay map ip 10.1.2.1 720
router ospf 1
SITE A when both hq1 and hq 2 wan was up
CCIE-BR1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-
       ia - IS-IS inter area, * - candidate default, U - per-user static ro
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
O       172.16.1.0 [110/65] via 10.2.1.1, 00:02:16, Serial0/2/0
C       172.16.2.0 is directly connected, FastEthernet0/0
C       10.10.101.0 is directly connected, FastEthernet0/0.130
C       10.10.201.0 is directly connected, FastEthernet0/0.240
O       10.34.255.0 [110/65] via 10.2.1.1, 00:02:16, Serial0/2/0
O    192.168.1.0/24 [110/65] via 10.2.1.4, 00:02:16, Serial0/2/0
     192.168.100.0/32 is subnetted, 1 subnets
C       192.168.100.3 is directly connected, Loopback0
-------------------------------SITE A sh ip route after int s0/2/0 on hq1 was shut down
Note that the subnet 172.16.1.0 is no longer on the routing table.
     172.16.0.0/24 is subnetted, 1 subnets
     10.0.0.0/24 is subnetted, 3 subnets
O    192.168.1.0/24 [110/65] via 10.2.1.4, 00:00:03, Serial0/2/0
CCIE-BR1#ping 172.16.1.2
Sending 5, 100-byte ICMP Echos to 172.16.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
CCIE-BR1#
Note:
Mohamed
Mohammed,
Thanks for your help. I saw what was wrong. When I issued a sh ip ospf neighbour from the branch sites, I saw that there no neighbour relationship formed to hq2. I observed that the command "ip ospf network broadcast" was missing from the serial interface. Immediately I did this, it worked as expected. When hq1 serial was down, I saw the Lan subnet advertised through hq2. Excellent! Many thanks
