Outbound load balancing
Paul Harris
We have two locations with connections to two different ISPs which provides redundancy/failover should either connection go down. This works fine but I would also like to implement some kind of load balancing to shift some of the load from ISP A to ISP B as the split is currently something like ISP A-95% and ISP B-5% and we quite frequently go above the commited rate on our ISP A connection.
The most simple method of doing this that I have found by googling is to use the BGP local preference attribute to force the routers to prefer ISP A for half of possible IP ranges (1.0.0.0 - 128.0.0.0) and to prefer ISP B for the rest.
I was wondering if anyone had tried this and how well it worked?
My concern is that it is an arbitrary way of determining path selection and as a result some customers may see performance degradation by having their traffic routed over a sub-optimal path.
Paul
Varun Uniyal
How are the devices on the inside learning the BGP routes? iBGP or some
IGP such as OSPF/EIGRP in which scenario you must be redistributing BGP into IGP?
You can always set local preference conditionally as follows :
neighbor x.x.x.x route-map TEST in
route-map TEST permit 10
match ip address
set local-preference
route-map TEST permit 20
match ip address
If you can run OSPF on the inside, then you can consider redistributing BGP into OSPF with E1 route-type , though redistributing BGP into IGP is not really a good idea.
If you have no IGP on the inside try running GLBP between the two edge routers...i am not sure of your topology so cannot say how feasible this will be.
paolo bevilacqua
With the fast Internet of today, that is no more a concern anyway. Unless your access circuits are undersized, or your ISP backbone is not up to standards, you have nothing to worry about, no matter what is routed where.
Varun Uniyal
match ip address
match ip address
Yes the internal devices are using iBGP.
I will have a go at setting the local route preference and see if it makes a difference.
Cheers
Paul
EDIT:
Actually if someone could just check the config I am intending to use to make sure it makes sense (I'm fairly new to BGP)...
Router A going to ISP A
router bgp 12345
neighbor x.x.x.x remote-as 56789
route-map test in
route-map test permit 10
match ip address 10
set local-preference 500
acess-list 10 permit 128.0.0.0 127.255.255.255
Router B going to ISP B
router bgp 12345
neighbor  x.x.x.x remote-as 54321
route-map test in
math ip adress 10
access-list 10 permit 0.0.0.0 127.255.255.255
Then presumably I'd need to restart the BGP session on both routers?
