PBR not working while using Eigrp
Syedalishah
Community Member
Hi Community,
I want to configure PBR for LAN subnet as when any of the user initiate the traffic for server packet should go to the ISP-2
e.g 192.168.40.20 destined to 192.168.16.55 it should follow the ISP-2 reaming traffic should follow ISP-1
I have configured. PBR but it's not working.
When Iam taking traceroute the traffic is going from ISP-1 for the destinations that i have defined in ACL for route-map
route-map LHRB, permit, sequence 10
Match clauses:
ip address (access-lists): LHRB
Set clauses:
ip next-hop verify-availability 172.16.3.69 10 track 1 [undefined]
ip next-hop 172.16.3.69
Policy routing matches: 0 packets, 0 bytes
Extended IP access list LHRB
10 permit ip 192.168.40.0 0.0.0.255 host 192.168.16.11
20 permit ip 192.168.40.0 0.0.0.255 host 192.168.16.72
30 permit ip 192.168.40.0 0.0.0.255 host 192.168.16.77
sh ip policy
Interface Route map
Gi0/0 LHRB
LHRB-RTR#sh ip eigrp neighbors
EIGRP-IPv4 Neighbors for AS(100)
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
1 172.16.3.69 Tu310 14 00:00:29 56 1470 0 27711
0 172.16.1.69 Tu110 13 03:45:57 40 1470 0 39005
(sec) (ms) Cnt Num
27 Replies 27
Policy routing matches: 439 packets, 70225 bytes
This meaning that traffic now hit pbr and must route via next-hop you use
Share
show track
MHM
Yes but when Iam taking trace it is still going from ISP-1
Track use for route-map need config ip sla' did you config any ip sla?
MHM
Match clauses:
Set clauses:
ip next-hop verify-availability 172.16.3.69 1 track 1 [down]
Track 1
IP SLA 1 reachability
Reachability is Down
1 change, last change 12:10:11
Latest operation return code: Timeout
Tracked by:
Route Map 0
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 192.168.3.69
frequency 10
ip sla schedule 1 life forever start-time now
There is likely your problem as I stated. Your tracked reachability is down. This needs to be in the up state to have your PBR work correctly. You need a valid UP and reachable IP address to bring up this SLA/Tracked object.
The next hop is  pingable why it showing me down?
Sending 5, 100-byte ICMP Echos to 172.16.3.69, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/20/24 ms
icmp-echo 192.168.3.69 source-interface <interface to ISP2>
You need to specify source interface in your command
MHM
I have specified the source interface as well but still status is down.
Set clauses:
Policy routing matches: 672 packets, 97240 bytes
ip sla 1
icmp-echo 172.16.3.69 source-interface Tunnel310
Now it's UP
but traffic going from ISP-1
Tracing the route to 192.168.16.55
VRF info: (vrf in name/id, vrf out name/id)
1 172.16.1.69 20 msec 20 msec 16 msec
2 192.168.3.17 20 msec 20 msec 20 msec
icmp-echo 172.16.3.69 source-ip <Tunnel310-IP>
Try use ip instead of interface
MHM
Sorry
This issue solve or not?
MHM
Hi MHM,
Not yet my traffic is still going from ISP-1 when Iam taking traceroute.
But I can see some traffic matches the ACL. I have on debugging but won't
see any log.
It bad news but I will run lab tomorrow check PBR with gre tunnel
Update you tomorrow with some result
Thanks for waiting
MHM
