PBR on Catalyst 3560g
mkashifashraf
Dear all,
I have WS-C3560G-24TS-S, i purchased CD-3560G-EMI= & updated the IOS with CD which sent by CISCO.In SH VERSION it shows that enhanced image is updated. Also PBR command on Interface mode is available now.
Switch(config-if)#ip policy route-map CISCO.
1- Does any activation key required for this update?
2- above mentioned command is accepted on interface mode but when i checked in show running. There were no command on interface mode.?
Please help me to sort out this issue.
Waiting for all.
3 Accepted Solutions
kathpric
Can you paste in the "show version"?  Also what type of interface are you trying to apply PBR on?  Could you paste in the configuration on this interface?  Does the switch give you any error when you try to apply the command?  Please paste in "show sdm prefer"  You may need to change to a routing template if you're currently using a desktop template.  Here is the configuration guide for changing the SDM template:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swsdm.html
Kathy
You can change it to desktop routing instead of desktop default.
conf t
sdm prefer routing
end
wr
reload
Make sure you reload or the change won't take affect.
Kathy
You must need to configure following in Cisco 3560g
-config t
-sdm prefer routing extended-match
-wr
-reload
Cheers!!!
kathpric
Kathy
Dear,
I saw in the below command, no IPv4 PBR access. So what is your recommendation that which type of SDM template will be used.
Please reply soon.
Core_2#sh sdm prefer
The current template is "desktop default" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
  number of unicast mac addresses:                  6K
  number of IPv4 IGMP groups + multicast routes:    1K
  number of IPv4 unicast routes:                    8K
    number of directly-connected IPv4 hosts:        6K
    number of indirect IPv4 routes:                 2K
  number of IPv4 policy based routing aces:         0
  number of IPv4/MAC qos aces:                      512
  number of IPv4/MAC security aces:                 1K
Core_2#sh ver
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
Core_2 uptime is 6 weeks, 4 days, 16 hours, 27 minutes
System restarted at 17:09:46 UTC Sun Nov 21 2010
System image file is "flash:c3560-ipservices-mz.122-25.SEB4/c3560-ipservices-mz.122-25.SEB4.bin"
cisco WS-C3560G-24TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID FOC1316Z41H
Last reset from power-on
6 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:25:46:E4:61:00
Motherboard assembly number     : 73-10215-04
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC13162QXH
Power supply serial number      : AZS131012SW
Model revision number           : D0
Motherboard revision number     : D0
Model number                    : WS-C3560G-24TS-S
System serial number            : FOC1316Z41H
Top Assembly Part Number        : 800-26851-01
Top Assembly Revision Number    : C0
Version ID                      : V03
CLEI Code Number                : CNMW200ARC
Hardware Board Revision Number  : 0x09
Switch   Ports  Model              SW Version              SW Image
*    1   28     WS-C3560G-24TS     12.2(25)SEB4            C3560-IPSERVICES-M
Configuration register is 0xF
Core_2#sh run int gi 0/20
Building configuration...
Current configuration : 132 bytes
interface GigabitEthernet0/20
description ***CORE2-P20-FW-P0/0***
no switchport
ip address x.x.x.x y.y.y.y
end
Core_2#
conf t
sdm prefer routing
end
wr
reload
Kathy
-config t
-wr
-reload
Cheers!!!
