Point to point connection using E1 network
husseinmuneer
Dear Sirs,
I want to connect 2 cisco 1721 router together through E1 network ( LAN 2 LAN ).
What is the interface cards which I need to install in the 1721 routers to connect the RJ45 E1 links ( need part #).
Thanking you for your help.
Regards.
muneer@yemen.net.ye
amar_5664
not sure what you are trying to achieve this is end of life model
you can use VWIC-1MFT-T1/E1 or VWIC2-1MFT-T1/E1
Leo Laohoo
I'm not sure VWIC-1MFT-T1/E1 or VWIC2-1MFT-T1/E1 will work.
Cisco One and Two Port T1/E1 Multiflex Voice/WAN Interface Card
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps282_Products_Data_Sheet.html
Rick Morris
Level 6
Level 6
Here is the link you need for this device:
http://www.cisco.com/en/US/partner/products/hw/routers/ps221/products_data_sheet09186a00800920ec.html
The card according to this data sheet is:
WIC-1T
One-port serial, asynchronous and synchronous (T1/E1)
or
VWIC-1MFT-E1
1-Port RJ-48 Multiflex Trunk - E1
http://www.cisco.com/en/US/partner/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml#platform
This link also provides the required IOS
