port Flapping
jahanzeb.feroze
I have set port channel in my switch Cisco 2960, and i receiving the following error since then,
Error: 40371: 5w2d: %SW_MATM-4-MACFLAP_NOTIF: Host e41f.13fc.7781 in vlan 1 is flapping between port Gi0/17 and port Gi0/15
Please guide me how to fix it, config of my switch is pasted below
Config:
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxxx
logging count
logging buffered informational
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
username nog1 secret 5 xxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login console-login local
aaa authentication login vty-login group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
clock timezone pst 5
system mtu routing 1500
ip subnet-zero
no ip source-route
no ip gratuitous-arps
no ip domain-lookup
ip domain-name cdcpak.com
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
 switchport trunk allowed vlan 1
 switchport mode trunk
 speed 1000
interface Port-channel2
 speed 1000
interface GigabitEthernet0/1
 description BA_DMZ (Assigned to Po1 for SMG purpose)
 speed 1000
 channel-group 1 mode active
interface GigabitEthernet0/2
 speed 1000
interface GigabitEthernet0/3
 switchport mode access
 speed 100
 duplex full
interface GigabitEthernet0/4
 speed 1000
interface GigabitEthernet0/5
 speed 100
 duplex full
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
 speed 1000
interface GigabitEthernet0/9
 speed 100
 duplex full
interface GigabitEthernet0/10
interface GigabitEthernet0/11
 speed 100
 duplex full
interface GigabitEthernet0/12
 speed 100
 duplex full
interface GigabitEthernet0/13
 speed 100
 duplex full
interface GigabitEthernet0/14
 description BA_DMZ (Assigned to Po2 for SMG purpose)
 speed 1000
 channel-group 2 mode active
interface GigabitEthernet0/15
 speed 1000
 duplex full
interface GigabitEthernet0/16
 speed 1000
interface GigabitEthernet0/17
 speed 1000
interface GigabitEthernet0/18
 duplex full
interface GigabitEthernet0/19
 duplex full
interface GigabitEthernet0/20
 shutdown
 speed 100
 duplex full
interface GigabitEthernet0/21
 media-type rj45
 speed 100
 duplex full
interface GigabitEthernet0/22
 switchport access vlan 105
 shutdown
 media-type rj45
 speed 100
 duplex full
interface GigabitEthernet0/23
 shutdown
 media-type rj45
 speed 100
 duplex full
interface GigabitEthernet0/24
 switchport trunk allowed vlan 99
interface Vlan1
 no ip address
 no ip route-cache
interface Vlan99
 ip address 10.x.x.x 255.255.255.0
 no ip route-cache
no ip http server
ip tacacs source-interface Vlan99
logging 10.2.41.11
logging 10.1.24.81
logging 10.1.222.35
logging 10.2.8.144
access-list 10 permit 10.1.24.21
access-list 10 permit 10.1.26.27
access-list 10 permit 10.1.26.26
access-list 10 permit 10.25.2.26
access-list 10 permit 10.1.26.31
access-list 10 permit 10.2.41.11
access-list 10 permit 10.1.26.33
access-list 10 permit 10.1.26.32
access-list 10 permit 10.2.41.23
access-list 10 permit 10.2.40.24
access-list 10 permit 10.1.24.81
access-list 10 permit 10.1.222.35
access-list 10 deny   any log
access-list 11 permit 10.2.41.11
access-list 11 permit 10.1.24.81
access-list 11 permit 10.2.8.144
access-list 11 permit 10.1.222.21
access-list 11 permit 10.1.222.20
access-list 11 permit 10.1.222.10
access-list 11 permit 10.1.222.35
access-list 11 deny   any log
no cdp run
snmp-server community t3hz33b RO 11
snmp-server host 10.1.222.35 version 2c t3hz33b
snmp-server host 10.1.24.50 version 2c t3hz33b
snmp-server host 10.1.24.81 version 2c t3hz33b
snmp-server host 10.2.41.11 version 2c t3hz33b
snmp-server host 10.2.8.144 version 2c t3hz33b
tacacs-server host 10.2.8.133 key 7 08154D4205003142425D5C
tacacs-server host 10.1.160.15 key 7 08154D4205003142425D5C
tacacs-server directed-request
radius-server source-ports 1645-1646
control-plane
banner login ^C This network devi^C
line con 0
 exec-timeout 15 0
 logging synchronous
 login authentication console-login
line vty 0 4
 access-class 10 in
 exec-timeout 15 0
 logging synchronous
 login authentication vty-login
line vty 5 15
 access-class 10 in
 exec-timeout 15 0
 logging synchronous
ntp authentication-key 1 md5 0034120D550E1F0721 7
ntp authenticate
ntp trusted-key 1
ntp clock-period 36029386
ntp server 10.1.222.100 key 1 source Vlan99 prefer
end
23 Replies 23
IBM servers are connected to port gig 0/15 and gig 0/17.
Ok i will configure duplex on g 0/17 as well and update if problem still persists
port-channel load-balance src-dst-ip
what to me mention in src-dst-ip ?
please read the link in my previous post.
swillet41
Did you ever resolve this flapping issue?  I have the same issue on a 2960 and wanted to see what IOS  you are using and what the fix was.  Can you pls elaborate on this?
Scott
Based on his replies, it was not an issue on the switch but on the server that is connected to it. Based on his replies, they did not configure NIC teaming on the server that's why flapping occured
Also, that is also most likely your issue, check the ports that flap on your side, verify the configuration on those ports and if those ports are in etherchannel, make sure the other end is configured for etherchannel as well
LJ, thanks for writing.  My system is not using Port-channel or Ether-channel config's.  It's a Netlab system powered by NDG for educational lab environments.
Scott
Check the ports that are flapping then, verify their configuration
Better yet why not create another post for this so we can better assist you xD
Nopes, issue didnt resolve yet
