Possible Dialer Watch bug?
m.belloni
Two cisco 2620XM, 128Mb Ram and 32Mb Flash and IOS c2600-is-mz.122-15.T13.bin, are active on the same Lan, with the hsrp function enable. One it's connected to the primary link and the second one starts isdn calls when the primary link goes down.
We configured the Dialer-Watch option and the backup run fine, but, after that the Primary Link comes up again, the backup router is going on to perform isdn calls and to stop it we have to shut and unshut the Dialer1. May you please check if there is one config error or if this is a cisco bug? I already checked the Tac case collection and the software bug tool and this Forum too but I didn't find any useful informations
I'm attaching the cisco configs and the sh ip route of the watched route when the primary link is in normal conditions
24 Replies 24
I was near to hope that my last modification which should have stopped the multicast traffic could have fixed, but unfortunately, after about two weeks of good performances, problem occured again. I performed some show with the problem active and others after its solution.I'm sure the destination address is difference from the one of the last outage
SHOW DURING THE PROBLEM
HSE-NECK#sh isdn active
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out ---N/A--- +0239640031 HSEMIMIB01 40 Unavail - 0
Out ---N/A--- +0239640031 HSEMIMIB01 5 Unavail - 0
HSE-NECK#sh dialer
Dial reason: ip (s=193.28.103.38, d=10.212.20.60)
Interface bound to profile Di1
Current call connected 00:00:51
Connected to 00390239640031 (HSEMIMIB01)
HSE-NECK#sh clock
12:23:44.709 GMT Thu Mar 24 2005
HSE-NECK#sh ip route 10.212.20.60
Routing entry for 10.212.20.0/23
Known via "static", distance 220, metric 0 (connected)
Redistributing via bgp 65184
Advertised by bgp 65184 metric 300
Routing Descriptor Blocks:
* directly connected, via Dialer1
Route metric is 0, traffic share count is 1
HSE-NECK#quit
[Connection to 10.10.10.2 closed by foreign host]
HSE-Neckarsulm-Primary>sh ip route 10.212.20.60
Known via "bgp 65184", distance 200, metric 300, type internal
Last update from 10.120.2.10 02:12:16 ago
* 10.120.2.10, from 10.120.2.10, 02:12:16 ago
Route metric is 300, traffic share count is 1
SHOW AFTER THE PROBLEM
HSE-NECK(config)#int dialer 1
HSE-NECK(config-if)#shut
HSE-NECK(config-if)#no shut
HSE-NECK(config-if)#^Z
ISDN ACTIVE CALLS
Known via "bgp 65184", distance 200, metric 0
Tag 2006, type internal
Last update from 10.120.2.9 00:01:26 ago
* 10.120.2.9, from 10.120.2.9, 00:01:26 ago
AS Hops 2
HSE-NECK#quit
Known via "bgp 65184", distance 20, metric 0
Tag 2006, type external
Last update from 146.198.71.53 00:01:38 ago
* 146.198.71.53, from 146.198.71.53, 00:01:38 ago
AS Hops 2
You have BGP routes flapping, resulting in your statics sending traffic to the dialer. So you need to find out why the routes are dropping from your BGP, or you need to re-configure so only dialer watch routes will bring up the ISDN link.
As another poster suggested, dropping the 'access-list 101 permit ip any any' will stop this from happening. At that point only dialer watch will activate the dialer.
So, by considering the acl
access-list 101 deny eigrp any any
access-list 101 deny ospf any any
access-list 101 deny tcp any any eq bgp
access-list 101 deny udp any host 255.255.255.255
access-list 101 deny udp any any eq ntp
access-list 101 deny udp any any eq snmp
access-list 101 deny udp any any eq snmptrap
access-list 101 deny ip any 224.0.0.0 15.255.255.255
you are suggesting me to cancel the last statement and keep all the previous ones, or to cancel all the acl?
Cancel away the last statement - however take note that you cannot do a "no access-list 101 permit ip any any", because that will remove the whole ACL 101.
Using a dialer-list will in fact reset the idle timer every time an interesting packet passes through. Hence it may not be a good idea to use dialer-list together with dialer-watch. I seriously question the purpose and actual usage of such a combination.
Therefore, I suggest removing the "dial-group" statement from your dialer interface - as that will definitely ensure any activation of the backup link is due to dialer watch.
OK, I removed the dialer-group statement as you suggested.Now only dialer-watch rules the backup
On last days we migrated the customer under a different platform by using one different routing protocol (eigrp instead of ospf) but as in the past isdn was activating calls also when the primary link was up,so, without a good reason. The config file attached is "Dialer watch new conf". If I delete acl 101 associated to dialer watch, the backup never run. Do you believe I can modify it by changing the last statement as "access-list 101 deny ip any any" just to try if this can stop this useless calls?
Or do you believe I can semplify the acl by only using the following statement: access-list 1 deny ip any?
One question: I verified that often the wrong and unnecessary isdn calls directs to destination addresses placed on the remote network 10.212.20.0/23.In which manner could I enable a debug ip routing only related to this remote network?
Below is the relevant config parts of my router (mind you it's using a PRI so all you need to do is substitute SPIDS in for the switch type stuff on the BRI and obviously BRI interface instead of Serial)
I had the same issue you were/are having. ISDN continued to dial in until I shut down the int. I no longer have that issue... since I put in the delay command. I originally tested this config with a BRI.
I am running IOS 12.3.13.
Today my primary failed (planned failover) and ISDN came up and went down when the primary came back....
interface Serial1/0:23
description d-channel
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn switch-type primary-4ess
isdn nsf-service sdn
no isdn gtd
ppp authentication pap
ppp multilink
interface Dialer1
ip address x.x.x.x 255.255.255.192
encapsulation ppp
dialer in-band
dialer idle-timeout 300
dialer map ip y.y.y.y name isdnrtr class sdnplan broadcast 5557777
! above y.y.y.y is the ip of my isdn rtr I am dialing into
dialer map ip z.z.z.z name isdnrtr class sdnplan broadcast 5557777
! above z.z.z.z is interesting dialer-watch traffic
dialer watch-group 1
dialer-group 1
ppp pap sent-username uname password 7 blahblahblah
ppp multilink
ppp multilink interleave
router eigrp 1
network x.x.0.0
network z.z.z.z
no auto-summary
dialer watch-list 1 ip z.z.z.z 255.255.255.0
dialer watch-list 1 delay route-check initial 200
dialer watch-list 1 delay connect 30
dialer watch-list 1 delay disconnect 20
dialer-list 1 protocol ip deny
Thanks for your update. I've unfortunately already setted the delay statement but my problem occured again. On yesterday I cancelled the dialer-group statement from Dialer1 as I want that only dialer-watch will be ruling the backup
mlanglois
Interesting... like I said earlier. I had a similar problem and fixed it by changing code rev and adding the delay command. The code rev you have doesn't support the delay command as far as I have noticed.
After the failover and ISDN dials, have you done a sho ip route and noticed if your Dialer routes actually ever leave? Use the include command to check... Some of my Dialer routes were never leaving until I used delay. I had TAC's opened and as I said before I had a CCIE send me a config. The only way I got it to work was I took everything out and added bits and pieces that seemed to make sense to me.
I originally was using the same rev of code you are.
