Power Supply / pinout for Cisco 4321?
radiomean1
Hi, I have C 4321 routers and a problem with a PSU. Does anyone know the pinout for a temporary solution?
The 6 pin socket is marked 12v and 54v - I assume the 54v is for PoE, and the router operates on 12v only?
Cheers!
radiomean1
OK, I have realised this is easy... Look for images of the PSU and the pinout is marked on the power brick!  Pins 1 and 4 are n/c, pins 2 and 3 are ground and pins 5 and 6 are 12v ...
