Switch can ping entire network, workstation cannot
Marcus023
Layer 3 switch (3650) can ping everything on the network.  But the workstation plugged into a port on that switch cannot ping past the start of the GRE Tunnel, which originates from that same switch, it cannot even ping the far end of the GRE Tunnel (the switch pings thru the tunnel to the rest of the network, so tunnel is up and functioning).  Originally, the workstation couldn't ping at all, until I set up a VLAN, assigned it an IP Address, manually set the IP and subnet of the workstation to match the network of the VLAN, and set the default gateway as the near end of the tunnel (near end of tunnel is the only thing other than the VLAN address that the workstation can ping). There is no IP Address on the port, just on the VLAN and workstation.  Switch port has been set up as trunk and access, pinging to the near end of the tunnel, and no further, each time.  The rest of the network is already fully functional, I just need the workstation to ping what the switch can already ping.
Yes the 3650 does not do subinterfaces. It accomplishes the same result using trunk. subinterface is a layer 3 concept which carries multiple vlans on a single connection. trunk does the same thing carrying multiple vlans on a single connection.
Your proposed solution with a router will require the 3650 to configure its interface to the router as a trunk. Then the router can use subinterfaces to process the various vlans.
Rick
18 Replies 18
Can I see how you config SW
MHM
workstation (VLAN10)-SW-GRE-Peer-Remote LAN
case1-
in SW the port connect to workstation need to be router port via
no swithport
and assign IP to this port
assign IP to workstation and make GW the port in SW
case2
in SW the port connect to workstation assign to specifc VLAN
add IP to this VLAN SVI
assign IP to workstation and make GW the SVI VLAN in SW
both case need
in SW
ip route <remote lan > tunnel <>
in Peer
ip route < router port OR VLAN SVI > tunnel<>
that all config you need
MHM
Had already done the 2nd one, will try the 1st one, thanks
1st idea was semi-successful.  Entire network can ping the port IP Address, workstation can ping the port IP Address, but workstation cannot ping rest of network nor can other devices ping workstation.
Both case need static route in SW and peer (other device of gre tunnel)
Did yoh configure static route in SW abd peer?
For 1st did you add ip to interface connect to workstation??
MHM
Static routes have been applied to the other devices and all of them ping the IP Address of the switch port.  Workstation has been assigned an IP Address in the same network range as the switch port (with same subnet mask, naturally).  Workstation can ping the port and even pings the near side of the GRE Tunnel (which is on the same 3650 as the port).  But the workstation cannot ping the far side of the GRE Tunnel or any other device.
In SW do following to know what is problem here
Ip access-list standard 10
Permit host <workstation IP>
Debug ip packet acl 10
Share debug output after you ping from workstation to far end of tunnel
Also share
Show ip interface breif <<- SW
MHM
The OP tells us " manually set the IP and subnet of the workstation to match the network of the VLAN, and set the default gateway as the near end of the tunnel". I would suggest changing the default gateway of the workstation to be the IP of the vlan interface where the workstation is connected.
There has been some discussion about whether the firewall of the workstation is preventing ping to the workstation. As a way to check on that I suggest that you try to ping the workstation from the switch to which it is connected.
And since there is some uncertainty about ping to the workstation I suggest that we focus on solving issues with ping from the workstation, and when that is working then  look at ping to the workstation.
Rick
Does the rest of the network know how to get to the subnet the workstation is on. Try a ping from the far end of the tunnel to the Workstations GW and then to the workstation. YOU may need to implement some kind of touting to provide reachability. Your switch may be able to ping because the rest of the network knows about the switch network but not the PC network.
Can you provide configs and a diagram?
-David
Due to static routing, the rest of the network can see the switch, but not yet the PC.
Suspected I might have to set up static routing for the pc, will give it a shot, thanks
Yes all devices need a route to the destination whether it be static routing or a dynamic routing protocol.
First device (router) to get a static route to the 3650 pings the vlan (vlan has IP) on the 3650 without issue.  Workstation pings the vlan on the 3650.  But router cannot ping workstation.  Workstation is on same network as the vlan.  How does the 3650 respond to a ping to the vlan ip but not the workstation ip?
I'm glad to see the router able to ping the switch vlan, because that shows the static route idea is the solution for the network.  But I don't get how the network can see the vlan on the switch, but not a workstation on the same network.  The static route on the router includes a /24 subnet mask, the vlan includes a /24 mask, so any number as the last octet for the workstation should still ping (1-254, of course).
Added static routes to entire network.  All devices can ping the vlan on the switch, but STILL NOT able to ping workstation.  Will add an IP address to the port and adjust static routes to point to that address.  If that works, hopefully workstation will ping too.
Workstation connect to SW on port with correct vlan?
Are Workstation use vlan svi as GW?
MHM
Hello
Turn off any software fw on the pc and test again, as by default windows disables echo-reply
Kind Regards
Paul
