PPP MultiLink Issue. Urgent!
kevin.john
There are two CE1 Line between HQ and Branch office router. Router in HQ is Cisco 7204VXR with PA-MC-STM-1SMI card and Router in Branch is Cisco 7204VXR with two CE1 cards. After use the following configuration to bundle two CE1 link to improve the bandwith, it's ok during the low traffic between the links(2.8Mbps or so). But when the traffic exceed 3Mbps or so, there will be some of packet lose and the speed showed in command 'show interface virtual-access 2' will drop sharply to very low speed such as 800kbps, then will go up slowly. Before use ppp multilink, I test two CE1 links which showed the quality is ok. so could you pls give me some comments and advice. Thanks. the configuration is showed as follows:
HQ:
multilink virtual-template 1
controller SONET 1/0
framing sdh
clock source internal
au-4 1 tug-3 1
tug-2 1 e1 2 channel-group 0 timeslots 1-31
tug-2 1 e1 2 framing no-crc4
tug-2 1 e1 3 channel-group 0 timeslots 1-31
tug-2 1 e1 3 framing no-crc4
interface Serial1/0.1/1/1/2:0
description link to branch
no ip address
encapsulation ppp
fair-queue
ppp multilink
ppp multilink group 1
interface Serial1/0.1/1/1/3:0
description link to branch-backup
no ip address
encapsulation ppp
fair-queue
ppp multilink
interface Virtual-Template1
ip address 10.201.115.1 255.255.255.252
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 xxx
ip ospf cost 48
ppp multilink
router ospf 1
network 10.201.115.0 0.0.0.3 area 115
area 115 authentication message-digest
Branch Office:
controller E1 1/0
framing NO-CRC4
channel-group 0 timeslots 1-31 speed 64
description Connect to SH HQ
controller E1 1/1
framing NO-CRC4
interface Serial1/0:0
description the First Connect to HQ
no ip address
encapsulation ppp
fair-queue
ppp multilink
interface Serial1/1:0
description the Second Connect to HQ
no ip address
encapsulation ppp
fair-queue
ppp multilink
ip address 10.201.115.2 255.255.255.252
ip ospf cost 48
ppp multilink
router ospf 1
paolo bevilacqua
Really one would need to see the show interface output to see amount of drops an possibly compare with a traffic graph to understand under which conditions they occur.
Beside this, what is the reason for mlppp in this design, given that fragmentation nor qos are enabled ?
Do you need perfect load balance, wouldn't be per-flow sufficient ?
You might want to turn off fair-queue. With fair-queue on you are trying to create seperate queues for each flow.
thanks for your reply.
I just changed to use ospf two equal-cost path to load balance. Although the load balance isn't very accurate as mlppp, it work. So customer at least accept this method. By the way, in the trouble shooting phase, i try to turn off fair-queue, but it didn't work well: speed of interface will still drop to a very low rate.
could you give me some further information and comments? thks.
