PRI + AT&T + SDN + primary-4ess
mlanglois
I have a 2600 with a PRI card, when I try to do an isdn test call int s1/0:23 ######### the debug constantly comes back with "Cause i = 0x83E020 - Mandatory information element missing" Vendor states he doesn't see the SDN 'flag' coming through. I have both the isdn nsf-service, and the dialer map configured to use a class with the outgoing sdn command. Anyone else run into this?
11 Replies 11
Josef Oduwo
Level 7
Level 7
Are your network specs right? Could we see all of your debug isdn q931, show isdn service outputs?
You can check and see whether you NSF supported services for AT&T switches match here http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800d9842.html#96209. Check the configuration for NSF call-by-call support (http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_configuration_guide_chapter09186a008008787b.html#xtocid2101619).
Also, the T1/E1 PRI troubleshooting flowcharts (http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00801509d7.shtml, http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a70fc.shtml) are good resources for finding out what may be wrong.
Cheers,
Josef.
ps - rate if it 'elps ;-)
Unfortunately I have poured through those doc's repeatedly.. tried every combination of nsf-service. Opened a TAC case, worked with the vendor... Last night a break through. TAC came through with a bug ID (one of those ones that normal folks like us are not privi to) so I'm trying a code upgrade. Which will subsequently break my dialer watch configuration I'm fairly certain.
have you tried the command isdn sending-complete. This should work by sending the call setup information
Just tried... no luck.. thank you though.
*Mar 1 19:49:17.207: ISDN Se1/0:23 EVENT: UserIdle: callid 0x800B received ISDN_CALL (0x0)
*Mar 1 19:49:17.211: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x000B
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Called Party Number i = 0xA1, '##########'
Plan:ISDN, Type:National
Redirecting Number i = 0x7FE080, 'n_parser_map_lkup'
Plan:Reserved, Type:Reserved
Redirecting Number i = 0x########
*Mar 1 19:49:17.267: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x800B
*Mar 1 19:49:17.271: ISDN Se1/0:23 EVENT: process_rxstate: ces/callid 1/0x800B calltype 1 CALL_REJECTION
*Mar 1 19:49:17.275: ISDN Se1/0:23 EVENT: process_rxstate: ces/callid 1/0x800B calltype 1 CALL_CLEARED
show isdn status
Global ISDN Switchtype = primary-4ess
ISDN Serial1/0:23 interface
dsl 0, interface ISDN Switchtype = primary-4ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 0
I forgot you had asked for a sho isdn service
PRI Channel Statistics:
ISDN Se1/0:23, Channel [1-24]
Configured Isdn Interface (dsl) 0
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3
Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2
I spoke to AT&T today... they removed the requirement for an nsf service to be passed by the cisco router and the ISDN came up... still pursuing cisco as to why it didn't work in the first place.
I'm fighting this exact same issue....did you find out what Cisco's issue was?
Unfortunately no. The site is in production now so I haven't been able to look into it more... although I do have another ISDN line to AT+T that's 'exclusively' dial in... that I may try to dial out with to figure out the issue. The work around was AT+T turned off the sdn service. If you would like I will send you the contact information of the people I worked with on the problem?
Thanks for the feedback. We ended up getting it to work by adding (isdn nsf-service megacom) to our serial interface.
e.g.
interface Serial1/0:23
no ip address
no logging event link-status
isdn switch-type primary-4ess
isdn incoming-voice voice
no cdp enable
Actually, AT&T wouldn't need to disable SDN, you would simply apply the following command to you serial interface to accept the SDN.
  isdn nsf-service sdn
jpalbujauser
