Priority Queuing: Incorrect Queue Counters
Dennis Olvany
I am trying to comprehend the following output of the show queueing interface command. It seems to be indicating matches on the high queue even though the high queue is not configured. Also, there are no matches indicated on the medium queue but matching traffic is present.
Lab-831#show queueing p
Current DLCI priority queue configuration:
Current priority queue configuration:
List   Queue  Args
1      low    default
1      medium protocol ip          list 111
Lab-831#show queueing int e1
Interface Ethernet1 queueing strategy: priority
Output queue utilization (queue/count)
        high/14 medium/0 normal/0 low/16
Lab-831#show access-l 111
Extended IP access list 111
    10 permit ip any any dscp af31
Lab-831#show access-l test
Extended IP access list test
    30 permit ip any any dscp af31 (9 matches)
    40 permit ip any any (11 matches)
Lab-831#show vers
Cisco IOS Software, C831 Software (C831-K9O3SY6-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 13:45 by prod_rel_team
ROM: System Bootstrap, Version 12.2(11r)YV3, RELEASE SOFTWARE (fc2)
Lab-831 uptime is 3 minutes
System returned to ROM by reload at 14:58:10 EDT Tue Oct 4 2011
System restarted at 15:00:04 EDT Tue Oct 4 2011
System image file is "flash:c831-k9o3sy6-mz.124-25d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C831 (MPC857DSL) processor (revision 0x500) with 58983K/6553K bytes of memory.
Processor board ID FHK095251Y3, with hardware revision 401D
CPU rev number 7
3 Ethernet interfaces
4 FastEthernet interfaces
128K bytes of NVRAM.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Lab-831#
paolo bevilacqua
Priority queuing is deprecated. Use Modular QoS instead.
