problem in cofiguring bridge domain
**Hamid**
I have configured a bridge domain between two ports of router (Gi 0/1 and Gi 0/2) and also i have configured a BDI interface and assigned an IP address (192.168.1.1/24) to it. In the picture below, you can see my topology.
my problem is, the two router in below could not ping the BDI interface IP address.
Thank you so much for your help
20 Replies 20
Blue_Bird
 Best regards
******* If This Helps, Please Rate *******
i've tried to configure IRB but in the interface configuration i could not find bridge group 1.
bridge irb
bridge 1 protocol vlan-bridge
bridge 1 route ip
(config)#interface gigabitEthernet 0/0/1
bridge-      <<<<<, there is not bridge command
bridge irb
bridge 100 protocol vlan-bridge <<- this must ieee not vlan-bridge
Bridge 100 route IP
only add this no need to change other config
my router has not ieee
only it has the below options
ast IBM protocol
dec DEC protocol
ibm IBM protocol
vlan-bridge vlan-bridge protocol
bridge 100 protocol vlan-bridge <<- no need this command then
try ping Now
the VRF in Routers is not effect reachable
1st configure bvi 1 then assign interfaces to bvi 1
1st configure
Config)#interface bvi 1
(config-if)# ip address  ip-address subnet-mask
Then
(config)# interface Gig0/2
(config-if)# bridge-group 1
(config)# interface Gig0/1
Best regards
