Problem with Fast Ethernet Hight-Speed WIC
elias.manchon
Hello folks,
I have a 2821 cisco router with two Gigabyte ethernet interfaces. I have adquired a 2-Port Fast Ethernet Hight-Speed WIC for Cisco Integrated Services Routers. I have followed the instructions to install this slot, I have choosed the 0 slot, I have tested it in other slot and I get the same result. When I power up the router, the all port leds is in green and when I issue the command "Show ip interface brief", I don't see the Fast Ethernet Interface in the interface list.
Is possible that the WIC is damaged or broken?
Could somebody help me, please?
Thanks in advance!!.
I have been recently checking the image requirement for this module and it seems the module requires 12.4(15T) as minimum version.I have also seen it wokring properly on 12.4(20)T.
Bhavesh
6 Replies 6
Jon Marshall
Elias
What IOS are you running ?
Jon
Hi Jon,
This is the system image file: c2800nm-advipservicesk9-mz.124-9.T7.bin
Thanks by your response!!
Bhavesh
Bufff!!
Now I have a great problem because I haven't support contract.
Do not try to do professional networking alone, engage a reputable consultant or cisco partner, and they will solve all your problems easily.
Hi Bebilacqua,
Not is sufficient with an ccna, ccnp in my enterprise?.
Greetings!!
