Problem with FE100 line cards on 7507 Router
Jesse Hottle
I have a 7507 router currently with 2x FE100 interface cards. I need to add another FE100 card. I have an open slot in an unused VIP, but the router will not detect the VIP or the FE100 card installed on this VIP. If I move the FE100 card to another open slot on a VIP card that is currently active in the router, the FE100 card is still not detected.
Any ideas?
jhottle
5 Replies 5
paolo bevilacqua
as you probably know, PA-level OIR is not supported, so you have to take out the whole VIP, add.change PA, and reinsert.
Hope this helps, if so please rate post!
I have an error with the VIP the FE100 card is installed on. I am not sure what to do. This VIP was purchased used, but does work.
Physical slot 6, ~physical slot 0x9, logical slot 6, CBus 0
Internal Instruction Error, Microcode Status 0x4
Master Enable, LED, WCS DBUS Cmd Enable, WCS Loading, WCS Loaded
Board is disabled
Pending I/O Status: None
EEPROM format version 1
VIP2 controller, HW rev 2.13, board revision A0
Serial number: 18315436 Part number: 73-1684-05
Test history: 0x00 RMA number: 00-00-00
Flags: cisco 7000 board; 7500 compatible
EEPROM contents (hex):
0x20: 01 15 02 0D 01 17 78 AC 49 06 94 05 00 00 00 00
0x30: 50 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
Slot database information:
Flags: 0x201 Insertion time: 0x3030 (14w3d ago)
VIP Controller Memory Size: Unknown
You say it works, but not in your chassis - it has been disabled, see above.
Is there (good) memory in it ?
I installed another 1-port FE100 card in another VIP on this router. The card is still not detected, but the other line card I have in the VIP is working fine. I have tried several different FE100 cards, which work fine in a 7206 router I have, but will not in my 7507. Why do you think this is happening and what can I do?
Not sure. PA-FE should be supported with a minimum of VIP2-15, possibly your VIP is VIP2-10 ? Have you tried both slots in the VIP2 ?
