Problem with Local Connected Route
viperthehero
Hello, i have a problem with my cisco ASR9K
RP/0/RSP1/CPU0:PE-XX#sh run int GigabitEthernet0/0/0/0.3838
Tue Feb 11 18:43:01.345 GMT
interface GigabitEthernet0/0/0/0.3838
description XX
bandwidth 128
service-policy input rate_limit_128k
service-policy output Package2-128k-parent
vrf cc
ipv4 address 10.111.21.1 255.255.255.0
encapsulation dot1q 3838
RP/0/RSP1/CPU0:PE-XX#show arp vrf cc GigabitEthernet0/0/0/0.3838
Tue Feb 11 18:43:06.763 GMT
0/0/CPU0
Address         Age        Hardware Addr   State      Type  Interface
10.111.21.1     -          4055.391f.6134  Interface  ARPA  GigabitEthernet0/0/0/0.3838
10.111.21.2     00:00:17   0025.64a6.a08e  Dynamic    ARPA  GigabitEthernet0/0/0/0.3838
10.111.21.10    00:13:49   0025.64a6.a08e  Dynamic    ARPA  GigabitEthernet0/0/0/0.3838
RP/0/RSP1/CPU0:PE-XX#show route vrf cc | i 3838
Tue Feb 11 18:43:14.780 GMT
i have configured properly this sub interface of my router, if i show the arp it detected, but why if i show route, there is no connected local route detected from my sub interface
i'm sorry if my english bad
thx a lot.
cadet alain
Maybe a stupid question but did you do sh ip route vrf cc ?
Alain
There is so many local, static, and connected route
RP/0/RSP1/CPU0:PE-D4-GBL-VPN#show route vrf cc | i Gig
Wed Feb 12 04:58:50.944 GMT
S    10.111.11.0/24 [1/0] via 172.31.100.222, 02:50:55, GigabitEthernet0/0/0/11.3821
S    10.111.141.0/24 [1/0] via 172.16.0.42, 02:50:55, GigabitEthernet0/0/0/0.2785
C    172.16.0.0/30 is directly connected, 02:50:55, GigabitEthernet0/0/0/0.2837
L    172.16.0.1/32 is directly connected, 02:50:55, GigabitEthernet0/0/0/0.2837
C    172.16.0.4/30 is directly connected, 02:50:55, GigabitEthernet0/0/0/0.2805
L    172.16.0.5/32 is directly connected, 02:50:55, GigabitEthernet0/0/0/0.2805
C    172.16.0.8/30 is directly connected, 02:50:55, GigabitEthernet0/0/0/0.2802
L    172.16.0.9/32 is directly connected, 02:50:55, GigabitEthernet0/0/0/0.2802
C    172.16.0.12/30 is directly connected, 02:50:55, GigabitEthernet0/0/0/11.2126
L    172.16.0.13/32 is directly connected, 02:50:55, GigabitEthernet0/0/0/11.2126
C    172.16.0.32/30 is directly connected, 02:50:55, GigabitEthernet0/0/0/0.2849
L    172.16.0.33/32 is directly connected, 02:50:55, GigabitEthernet0/0/0/0.2849
RP/0/RSP1/CPU0:PE-D4-GBL-VPN#show ipv4 vrf cc interface GigabitEthernet0/0/0/0.3838 brief
Wed Feb 12 05:04:17.971 GMT
Interface                      IP-Address      Status                Protocol
GigabitEthernet0/0/0/0.3838    10.111.21.1     Up                    Up
RP/0/RSP1/CPU0:PE-D4-GBL-VPN#show ip route vrf cc | i 3838
Wed Feb 12 05:00:10.415 GMT
but none of vlan 3838 is detected as local and connected in this PE
is that a bug ? or maybe the subinterface in my asr is full
this is the capture of total circuit in my PE
RP/0/RSP1/CPU0:PE-XX#show interfaces summary
Wed Feb 12 05:14:21.244 GMT
Interface Type          Total    UP       Down     Admin Down
ALL TYPES               2240     1872     2        366
IFT_GETHERNET           40       11       0        29
IFT_VLAN_SUBIF          2182     1856     0        326
IFT_LOOPBACK            1        1        0        0
IFT_ETHERNET            4        0        1        3
IFT_NULL                1        1        0        0
IFT_TENGETHERNET        12       3        1        8
sry if my question is stupid, i desperately want to troubleshoot this problem in my workplace
thx for the help
