QoS Configuration - police cir - netflow - problem
fabiogarcia
Dears,
I have this configuration at my router, can anybody do a suggestion ?
Sorry the long post... tried to simplify as much as I could.
ip access-list extended SHAPE_TRAFEGO_SRC_172.17.196.12
permit ip host 172.17.196.12 any
permit ip any host 172.17.196.12
class-map match-any SHAPE_TRAFEGO_SRC_172.17.196.12
match access-group name SHAPE_TRAFEGO_SRC_172.17.196.12
policy-map qos_new
class SHAPE_TRAFEGO_SRC_172.17.196.12
  police cir 8000
    conform-action transmit
    exceed-action drop
    violate-action drop
class class-default
  fair-queue
policy-map PARENT_qos_new
class class-default
  shape average 2000000
  service-policy qos_new
**** Thats a Frame relay interface ******
interface Serial0/1/1
description XXXXXX
no ip address
encapsulation frame-relay IETF
invert txclock
interface Serial0/1/1.777 point-to-point
description XXXXXXX
bandwidth 2048
ip address 172.26.0.65 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
ip flow egress
frame-relay interface-dlci 777
    service-policy output PARENT_qos_new
That should be policing all that traffic to 8kbps... but in my NETFLOW tool, I see traffic going above that limit.. a lot of times... below an example
We can see easily that traffic goes at 300Kbps limit...
I see that traffic is using that police as well... but not really policed...
router#sh ip access-lists SHAPE_TRAFEGO_SRC_172.17.196.12
Extended IP access list SHAPE_TRAFEGO_SRC_172.17.196.12
    10 permit ip host 172.17.196.12 any
    20 permit ip any host 172.17.196.12 (2067609 matches) <<<<<<<< increasing all the time
Any suggestion ?
15 Replies 15
Terry Cheema
Was the link congested at that time? QoS would only kick in when your link experiences congestion.
class class-default
  shape average 2000000   <<< You are shaping at close to 2Mb
Unless your link is overflowing more than 2Mb - whatever traffic comes in goes out without any policing queuing. When the 2Mb mark is reached then your traffic would start getting the defined behavior. Then it would police at 8kbps. Which is the correct behavior.
The possibilty is your link was not congested during that periods.
IMHO, the policer should work all the time, no matter if the line is congested or not..
But it's restricting traffic from/to a single host 172.17.196.12.
While the NetFlow example is showing traffic from another host which is not matching the ACL.
HTH,
Milan
Milan - You could be right - but I beleive since the parent policy is shaping and then the child policy is applied under it has the policer defined, its not active all the time. I am typing from phone so cant exactly copy paste - but I think if policer was applied directly under the Parent policy first, before any other policy, then it would by pass Shaping and would police all the time...
But at the moment parent policy is shaping traffic at 2 Mbps, child policy has other treatment along with policer, thats why I think unless parent policy signals bandwidth congestion, the child policy will not kick in..
Interesting, Lets seek some more comments .....
Thanks for replying buddy.
Terry
Hi Terry,
I still believe the policer should work all the time.
It would be interesting to repeat
show policy-map interface Serial0/1/1.777 out
command several times and check if the policer counters are showing any drops increasing.
BR,
Milan
Interesting - Anyone else, would like to share views?
Terry
Hello Terry,
I agree with Milan.
the nested QoS policy applies policing only to two distinct traffic flows having IP source or IP destination a specific host.
However, nothing in the configuration blocks other traffic just there is a shaper to 2Mbps in the parent policy map.
So seeing traffic peaks on the interface of up to 300 Kbps < 2 Mbps is not a sign of a problem.
As suggested by Milan the show polcy-map interface counters can answer to the question and they should show policing in effect.
Hope to help
Giuseppe
Giuseppe,
Thanks for taking the time to reply and clearing this up +5 to you and Milan(all posts) - cant do more than that . It means explicit policer is always ON even if its in a Child Policy and is bypassing the Parent shaper. Congestion or no congestion, Hierarchical or not - explicit policer is always ON.
Fabio,
This one from Giuseppe is for your clarity:
Terry
fabiogarcia
Dears
First of all THANKS FOR EVERYONE whos trying to help me.....
And SORRY for my reply... I was out of office doing other jobs these days... please find below the output requested...
The output below shows all results for all classes (not only the class I am concerning about)
router#show policy-map interface Serial0/1/1.777 out
Serial0/1/1.777
  Service-policy output: PARENT_qos_new
    Class-map: class-default (match-any)
      61465416 packets, 13711229376 bytes
      5 minute offered rate 259000 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
          2000000/2000000   12500  50000     50000     25        6250
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         55807037  2742354205 347175    400791112 no
      Service-policy : qos_new
        Class-map: voip (match-any)
          750758 packets, 144475769 bytes
          5 minute offered rate 0 bps, drop rate 0 bps
          Match: ip dscp ef (46)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: ip dscp cs5 (40)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: ip dscp cs6 (48)
            71955 packets, 4219931 bytes
            5 minute rate 0 bps
          Match:  dscp ef (46)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match:  dscp cs5 (40)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match:  dscp cs6 (48)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: ip precedence 5
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match:  precedence 5
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: protocol skinny
            55964 packets, 27501612 bytes
            5 minute rate 0 bps
          Match: protocol rtp audio
            622840 packets, 112754430 bytes
            5 minute rate 0 bps
          Queueing
            Strict Priority
            Output Queue: Conversation 72
            Bandwidth 10 (%)
            Bandwidth 200 (kbps) Burst 5000 (Bytes)
            (pkts matched/bytes matched) 1319/765920
            (total drops/bytes drops) 44/63394
        Class-map: PRIOR_SHIVA_THRU_ATT (match-any)
          994676 packets, 119261474 bytes
          Match: access-group name PRIOR_SHIVA_THRU_ATT
            5 minute rate 0 bps
          Queueing
            Strict Priority
            Bandwidth 5 (%)
            Bandwidth 100 (kbps) Burst 2500 (Bytes)
            (pkts matched/bytes matched) 1288/252691
            (total drops/bytes drops) 31/46624
        Class-map: SHAPE_TRAFEGO_SRC_172.17.196.12 (match-any)
          13753357 packets, 3086579457 bytes
          5 minute offered rate 62000 bps, drop rate 55000 bps
          Match: access-group name SHAPE_TRAFEGO_SRC_172.17.196.12
            13753356 packets, 3086579457 bytes
            5 minute rate 62000 bps
          police:
              cir 8000 bps, bc 1500 bytes, be 1500 bytes
            conformed 8123233 packets, 731084041 bytes; actions:
              transmit
            exceeded 4002688 packets, 409236337 bytes; actions:
              drop
            violated 1627496 packets, 1946298475 bytes; actions:
              drop
            conformed 7000 bps, exceed 0 bps, violate 55000 bps
          31175903 packets, 8285525763 bytes
          5 minute offered rate 120000 bps, drop rate 0 bps
          Match: any
          Queueing
            Flow Based Fair Queueing
            Maximum Number of Hashed Queues 64
        (total queued/total drops/no-buffer drops) 0/428/0
router#
Do you guys suggest another value for my MAIN policy ... ?
class class-default
  shape average 2000000 <<<<<<<<<<<<<<<<<<< (???)
Thanks in advance!!!!
Hello Fabio,
as suggested by Milan the show policy-map interface output shows that policing is active in the child policy map and that traffic in excess of the policing rate is actually dropped. This applies only to specific traffic flows as noted in previous posts in this thread.
The shaping rate in the parent policy applies to ALL traffic that is sent out on the link and should be less equal of access link rate.
If it is so, you are fine with this rate. If the actual speed of the link is lower then 2000000 bps then you should lower it.
Edit:
and also the shaping rate has to be less equal then the contracted rate ( CIR) agreed with the SP for which your company/client is paying for.
Hope to help
Giuseppe
I agree wit Giuseppe.
As you can see in your output:
Serial0/1/1.777
Match: any
Traffic Shaping
So the whole traffic to sent out from the interface is coming with 259 kbps speed - far not reaching the 2 Mbps shaping target.
That's why the shaping is NOT active at the moment.
On the other side:
police:
transmit
drop
drop
So the child policer is active, dropping the traffic exceeding the CIR configured.
As I said in the beginning:
If you want to restrict the traffic originated from other sources, you just need to add them to the ACL used in the child policer.
HTH,
Milan
Dears,
Again thanks everyone for all help and time spent with my problem!!!!
I can guarantee that during the first message I was facing cogestion... and from the router I see everything well... the traffic is being policed doesnt matter the total rate on the link... But the main problem is my netflow tool (from manage engine called "Netflow analyzer") ... When I check each flow with that IP I see that the traffic is pretty much above the police I used...
From the same policy-map I have another class which should be policed to 128K (output below is from a non congested time window)
Class-map: SHAPE_TRAFEGO_SYMANTEC_CORP (match-any)
          15744681 packets, 2198483815 bytes
          5 minute offered rate 35000 bps, drop rate 0 bps
          Match: access-group name SHAPE_TRAFEGO_SYMANTEC_CORP
            15744681 packets, 2198483771 bytes
            5 minute rate 35000 bps
          police:
              cir 128000 bps, bc 4000 bytes, be 4000 bytes
            conformed 15707067 packets, 2165838164 bytes; actions:
              transmit
            exceeded 30287 packets, 24900396 bytes; actions:
              drop
            violated 7498 packets, 7783805 bytes; actions:
              drop
            conformed 37000 bps, exceed 0 bps, violate 0 bps
This is the ACL
ip access-list extended SHAPE_TRAFEGO_SYMANTEC_CORP
permit ip host 172.21.252.223 any
permit ip any host 172.21.252.223
In other words, that class should never exceed 128K... right ?? (doesnt matter if the traffic is congested or not....)
But look my netflow.... I can easily see an unique flow exceeding and reaching 1.5Mbps during 1 hour time window...
Is it correct affirm that traffic should be policed to 128K all the time ?
Why we see an unique flow reaching 1.5Mbps ?
Thanks in advance!!!!!
interesting!
I understand you are running NetFlow on the same interface the policer is applied?
Could you provide the whole NetFlow configuration from your router?
I'm not sure what is the order of NetFlow/policer drop operations.
Possibly NetFlow collects the statistics before the policer drop is applied?
BR,
Milan
Thanks for your help..
Actually I did the netflow configuration following the vendor documentation
This is the configuration
router#sh run int Serial0/1/1.777
Building configuration...
Current configuration : 294 bytes
description MPLS PRI AT&T XXXXXXXXXXXXXXX
bandwidth 2048
ip flow ingress
ip flow egress
end
Also we have
ip flow-cache timeout active 1
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination X.X.39.139 2055
Also, exactly right now... I see that in my netflow (traffic from 172.21.252.223 is reaching 1.2 Mbps)
This is my policy map
          20576508 packets, 3054240429 bytes
          5 minute offered rate 96000 bps, drop rate 1000 bps
            20576507 packets, 3054240333 bytes
            5 minute rate 96000 bps
          police:
            conformed 20500879 packets, 2983476986 bytes; actions:
              transmit
            exceeded 49242 packets, 42997686 bytes; actions:
              drop
            violated 26746 packets, 27797370 bytes; actions:
              drop
            conformed 96000 bps, exceed 2000 bps, violate 0 bps
This is the access-list (increasing the logs)
router#sh ip access-lists SHAPE_TRAFEGO_SYMANTEC_CORP
Extended IP access list SHAPE_TRAFEGO_SYMANTEC_CORP
    10 permit ip host 172.21.252.223 any (16 matches)
    20 permit ip any host 172.21.252.223 (20599387 matches)  <<<<<<<<<<<<<<<<<<
Thats weird... In the netflow graphs I see a lot of traffic ... but in the router I see only traffic around 96Kbps (which is not reaching the limit of policy cir configured >> 128K)
Hello Fabio,
I again agree with Milan
The order of operations may explain the mismatch in output results between what is seen in Netflow and the output of QoS shaper/policer.
If Netflow processes the packets before they are processed by QoS tools it may account for dropped traffic.
Hope to help
Giuseppe
