02-23-2012 06:23 AM - edited 03-04-2019 03:24 PM
When configuring QOS over an MPLS do we need to have our provider add any commands to there routing, or is it just our edge routers, and they just pass them through regardless? Is there a good article that some one can point me to regarding QOS over MPLS?
Solved! Go to Solution.
02-23-2012 06:36 AM
You need to work with your provider if you are planning to use QoS in a MPLS Backbone.
While you can configure QoS at your locations, if the provider runs into congestion,
those packets will be dropped regardless of your QoS tags.
Your provider will guide you on the type of service they offer and how much it will cost for each class.
For instance, they tend to charge premium for priority queuing class depending upon how much PQ you need.
You don't need to do much at your end other than configuring your flows according to the provider's policies.
Edison
02-23-2012 06:36 AM
Edison
02-23-2012 06:47 AM
Thanks again Edison,
I am seeing the light at the end of the tunnel.
02-23-2012 10:56 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Much depends on what all you mean by over MPLS.
Assuming you're using MPLS as a L2 or L3 cloud, you generally need to provide your own QoS as you send traffic into that cloud (much like frame-relay or ATM clouds). Additionally, if your MPLS cloud supports multipoint, and you take advanage of that, you'll often need QoS support from you MPLS cloud vendor. Most MPLS cloud vendors can provide optional QoS, often at additional cost.
However, if you run a logical hub-and-spoke topology across a MPLS cloud, you don't always need QoS support from your vendor (again much like frame-relay or ATM).
If the foregoing is what you have in mind, an article is probably inadequate to explain. One of Cisco's Design Guides would be a good start, e.g. http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html. But to really understand what's involved you may need a book, such as: http://www.ciscopress.com/bookstore/product.asp?isbn=1587051761, (I don't believe I've read this one, but Cisco Press books generally are good to excellent.)
