QoS Queues - Why is ef queue empty?
r.stockton
I have the following policy in place and am unsure as to why the ef  queue is empty.  I see the ef packets being matched and the first  portion of the output indicates ef packets going to the priority queue,  but the following table shows the ef queue shows 0/0 accross the board  and the other packet counts don't seem to add up.  Oh and what is the "cs6"
Thanks!
sho policy-map in s0/0/0
  Serial0/0/0
    Service-policy output: qos
      Class-map: enhanced (match-any)
     18929450 packets, 1332072895 bytes
     5 minute offered rate 0 bps, drop rate 0 bps
     Match: ip dscp af31 (26)
       5 minute rate 0 bps
     Queueing
       Output Queue: Conversation 265
       Bandwidth 384 (kbps)Max Threshold 64 (packets)
       (pkts matched/bytes matched) 2355392/230029119
       (depth/total drops/no-buffer drops) 0/8977/0
      Class-map: high (match-any)
     532831636 packets, 98884721243 bytes
     5 minute offered rate 28000 bps, drop rate 0 bps
     Match: ip dscp ef (46)
       5 minute rate 28000 bps
     Queueing
       Strict Priority
       Output Queue: Conversation 264
       Bandwidth 33 (%)
       Bandwidth 509 (kbps) Burst 12725 (Bytes)
       (pkts matched/bytes matched) 464933441/93016817984
       (total drops/bytes drops) 0/0
      Class-map: class-default (match-any)
     716229182 packets, 359913582844 bytes
     5 minute offered rate 78000 bps, drop rate 0 bps
     Match: any
     Queueing
       Flow Based Fair Queueing
       Maximum Number of Hashed Queues 256
       (total queued/total drops/no-buffer drops) 0/262326/0
       exponential weight: 9
    dscp    Transmitted      Random drop      Tail drop    Minimum Maximum  Mark
         pkts/bytes       pkts/bytes       pkts/bytes    thresh  thresh  prob
     af11 442253270/187375309113   4279/1367847    25282/6128087     32      40  1/10
     af12       0/0               0/0              0/0           28      40  1/10
     af13       0/0               0/0              0/0           24      40  1/10
     af21       0/0               0/0              0/0           32      40  1/10
     af22       0/0               0/0              0/0           28      40  1/10
     af23       0/0               0/0              0/0           24      40  1/10
     af31       0/0               0/0              0/0           32      40  1/10
     af32       0/0               0/0              0/0           28      40  1/10
     af33       0/0               0/0              0/0           24      40  1/10
     af41       0/0               0/0              0/0           32      40  1/10
     af42       0/0               0/0              0/0           28      40  1/10
     af43       0/0               0/0              0/0           24      40  1/10
       cs1       0/0               0/0              0/0           22      40  1/10
       cs2       0/0               0/0              0/0           24      40  1/10
       cs3       0/0               0/0              0/0           26      40  1/10
       cs4       0/0               0/0              0/0           28      40  1/10
       cs5       0/0               0/0              0/0           30      40  1/10
       cs6 1886907/155518082       0/0              0/0           32      40  1/10
       cs7       0/0               0/0              0/0           34      40  1/10
       ef       0/0               0/0              0/0           36      40  1/10
     rsvp       0/0               0/0              0/0           36      40  1/10
   default 271826679/172030878784 229072/338913149   3693/5467782     20      40  1/10
Lei Tian
The "following table" is for class-default; EF packets are matched in "high" class, and put in priority queue. C6 could be the routing protocol, or other control plane traffic.
HTH,
Lei Tian
Mohamed Sobair
Level 7
Level 7
The default class is assigned (IP Precedence =1) , (AF11) by default if not marked. and thats what the table indicates.
the ef is matched in the class and put into priority queue,
Mohamed
r.stockton
Ahh, ok.
So, the table is simply listing anything not matched and queued in the policy-maps.   Correct?
Am I now reading this correctly:
- Conversation 264 is the Priority Queue with 33% of the bandwitch.  This is for all ef packets
- Conversation 265 is some other queue with 384k for af31 packets.  <---what is this queue?
- ramaining traffic goes to the default-queue and we are seeing af11 (default marked) and cs6 (possible routing protocols, etc)
- what is "default" traffic at the bottom of the table?
Thanks for your assistance, both of you.
That is correct.
Class "enhanced" matches packets with dscp af31, and it uses conversaction 265; class "high" matches packets with dscp ef, and it ues conversaction 264. The rest traffic are in "class-default". There are 3 type of traffic in class-default, traffic with dscp cs6, af11 and default(0). You need to check the marking configure to see what traffic is been marked to af11 or 0.
HTH,
Lei Tian
