Router 2951
xXAJXx
Are WIC-2T compatible with 2951 Routers and If so is there a command to enable the interfaces?
No, those are not supported in the 2900/3900 family.
Okay Thank you.
Leo Laohoo
No, not supported and they will not "fit" into the slot without permanently damaging the pins.
If I remembered correctly, all WIC/NM for the ISR G2 need to have the "H" in the prefix:  HWIC-2T
