question regarding crash
SPYME.GOOGLE
hi
how do we capture crashinfo file from rommon mode. how do we capture stack traces from this rommom mode.
purohit_810
Level 5
Level 5
Can you tell me is it Router OR Switch?
Which model?
Dharmesh Purohit
hi
this for a 3600 router. i want to know in general how to collect crashinfo file from rommom mode on any type of platform
vaisharm
There's no way any file can be copied from ROMMON mode. You can only view the contents of the flash from ROMMON mode (using 'dir flash:'). However, if the router was not 'manually' power cycled after the crash, you may obtain a stack trace from ROMMON which can be decoded to obtain more information about the crash. The commands that can be used are:
ROMMON1>sysret
or
ROMMON1>stack 50 or 'k 50'
Obtain a Stack Trace from ROM Monitor
http://www.cisco.com/warp/public/63/why_hang.html#ktrace
Note: The stack trace collected this way may not always be very useful in diagnosing a crash.
Alternately, if the crashinfo is stored on a PCMCIA flash card, you may take it out and use it on a similar router or on a laptop with PCMCIA dlash card reader.
-Vaibhav
