Remotely Turn off router
acbenny
is it possible to remotely turn off the router by any command.
6 Replies 6
pushkar1782
hi
just telnet into the router and
router# reload
I want to switch off the router remotely , not restart. is it possible to do it ?
nope, not yet found a method to do so...
regds
If the link is not required any more then telnet into the router and issue Write erase cpmmand to delete the config and then issue reload command without saving the config.
This will ensure the link is gone forever.
Hope this helps
Shaheen
Acbenny,
Not usually something want in their routers. You might find APC or other UPS manufacturer has something where you can remote power down an attached device.
http://www.apc.com/products/family/index.cfm?id=151
Naturally you'll have the problem of how to turn the device back on, you'll have to have out of band management sorted prior to turning the router off.
Tony
you can get a blackbox NPS which will allow to turn the router or any other devices on and off.
This is what my co-locations customers use.
